Mobian PIN changed after update!
#21
I stumbled on the Mobian Release Notes. I went through the process of reloading Mobian and the install instructions states that the screen unlock code is set to "1234" the same code as on my luggage.
All is well now.
  1. Restart your device: Sometimes a simple restart can resolve temporary issues. Try rebooting your device and see if the default PIN starts working again.
  2. Reset the PIN: If a restart doesn't work, you may need to reset the PIN. To do this, you can try the following steps:
  • Boot your device into recovery mode (the process may vary depending on your device).
  • Look for an option to reset or clear the PIN or password.
  • Follow the on-screen instructions to complete the reset process.
  • Once the reset is done, you should be able to access your device with the default PIN.
Cool Heart
  pinephone-support package not upgradable on Mobian fhireman 5 6,702 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 6,677 02-28-2026, 04:18 PM
Last Post: baptx
  What is wrong with the Mobian signature key? Mahgue 0 844 11-08-2025, 05:13 AM
Last Post: Mahgue
  Clamares password needed with new Mobian installation fauvetan 1 2,689 06-26-2025, 03:00 AM
Last Post: merom
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 3,597 12-05-2024, 06:42 AM
Last Post: gilford
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 13,439 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 7,791 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No longer waking up from sleep after recent update gamerminstrel 2 3,672 01-23-2023, 08:33 AM
Last Post: gamerminstrel
  No sound after Mobian upgrade arbocenc 1 2,638 11-28-2022, 11:02 AM
Last Post: arbocenc
  no sdcard boot and manjaro update failed Gwen 3 4,445 11-27-2022, 07:56 AM
Last Post: fxc
