power usage for Pine64 LTS + Screen
my pine doesn't seem to be charging the 5000mAh battery while the screen is on unless i turn the brightness way down using the 2A power supply,
i guessing its using more power then it can get, i have a 5v 3A on its way
does any 1 know how much power the
board + 7inch screen + wifi/ bt module not turned on + camera not turned on should be using?
will a 3A power supply be enough to charge the battery while its on be enough?
has any 1 else had any similar issues to this?
much better now with a 3A power supply
  pine64 gpio interrupts fractal 0 11,451 12-09-2024, 07:43 PM
Last Post: fractal
Question How to connect a pine64-LTS to a serial console? zuvmajujo 1 4,597 04-02-2023, 05:09 PM
Last Post: zuvmajujo
  Pine64 LTS won't boot zuvmajujo 1 4,168 04-02-2023, 04:59 PM
  Has anyone gotten "reset" to work in U-Boot for Pine64? Pine 1 7,887 04-19-2021, 12:55 PM
Last Post: Pine
  Pine64 LTS GbE Problem scchoi 1 6,918 06-20-2020, 12:39 PM
  Selling my Pine64 2gb LTS with a bunch of accessories poponon 0 4,599 08-08-2019, 09:01 PM
Last Post: poponon
  Is the power source exposed to the OS? seal 4 12,166 07-20-2019, 12:14 PM
Last Post: pkfpeters
  change the charge LED indicator to Mode B on Pine64 LTS JTX 0 4,176 04-12-2019, 06:34 PM
Last Post: JTX
  Pine64 LTS Boot Media order Akash Gajjar 1 5,719 07-22-2018, 05:29 PM
  Pine64 LTS Not booting krisclarkdev 2 6,772 05-13-2018, 10:22 PM
Last Post: krisclarkdev
