How to connect a pine64-LTS to a serial console?
Question
I'm trying to get two separate pine64 LTS boards to boot for the first time. Previous troubleshooting attempts here: https://forum.pine64.org/showthread.php?tid=17961.
I was hoping to monitor the serial port of each board to find some some helpful errors. I couldn't find a post specifically for the pine64 LTS but I did for the rock64: https://forum.pine64.org/showthread.php?tid=5029. I connected to pin 6 (GND <-> GND), pin8 (TX -> RX), and pin10 (RX -> TX). As a sanity check I switched RX and TX to make sure I hadn't mis-connected something. I've tested the serial console on another dev board so I know it's working. I'm on Ubuntu 22.04 and I'm using the following command to read messages:
sudo  minicom  -s  -D  /dev/ttyUSB0  -b  1500000  --color=on
I checked that the serial console is connected to /dev/ttyUSB0 by using the command:
ls -l /dev/serial/by-id
Absolutely nothing comes through minicom from both boards. I thought perhaps the steps for the rock64 are different for the pine64. Please enlighten me if so.
The instructions to connect to a serial console are not on the Pine64 LTS Wiki, but they're on the linux-sunxi wiki for the device: https://linux-sunxi.org/Pine64-LTS#Serial_port_.2F_UART
I used the pins on the EXP header and got the console to work.
[Image: Pine64_UART0.jpg]
  getting second serial port available gadgetguy 1 751 11-26-2023, 09:29 AM
Last Post: gadgetguy
  Pine64 LTS won't boot zuvmajujo 1 947 04-02-2023, 04:59 PM
Last Post: zuvmajujo
  Has anyone gotten "reset" to work in U-Boot for Pine64? Pine 1 3,454 04-19-2021, 12:55 PM
Last Post: Pine
  power usage for Pine64 LTS + Screen Little_Johnny 1 2,972 02-17-2021, 07:19 PM
Last Post: Little_Johnny
  Pine64 LTS GbE Problem scchoi 1 4,059 06-20-2020, 12:39 PM
  Selling my Pine64 2gb LTS with a bunch of accessories poponon 0 2,608 08-08-2019, 09:01 PM
Last Post: poponon
  change the charge LED indicator to Mode B on Pine64 LTS JTX 0 2,546 04-12-2019, 06:34 PM
Last Post: JTX
  Pine64 LTS Boot Media order Akash Gajjar 1 3,363 07-22-2018, 05:29 PM
  Pine64 LTS Not booting krisclarkdev 2 4,041 05-13-2018, 10:22 PM
Last Post: krisclarkdev
  Pine64 LTS - DOA harcrow 8 8,475 03-30-2018, 02:13 PM
Last Post: davidgs
