How to reinstall a broken OS on Pinephone's internal storage?
Hi, I've been Pinephoning since November and things got a bit wonky recently. I kept getting annoying on-screen phone shell alerts, and noticed that connectivity seemed to be dropping out when the phone went to sleep, and I was also concerned that I may have missed calls.
More recently I discovered that the phone could no longer retrieve and install updates, which left me wondering how to overwrite the internally stored OS from scratch.
So I went to Manjaro and downloaded the ARM Beta 5 Phosh version, flashed a microSD and booted my Pinephone from that.
I had hoped that it would present me with an option to install the OS to the internal storage, but keep my phone contacts in the process. It didn't, and I can't find a prompt anywhere to achieve that.
Could someone point me in the right direction please? Big Grin
Thanks in advance.
So I've had a bit of a dig on the forums here, and found some excellent advice from member SwordfishII.
He/she suggests the following steps for flashing an OS image to your phone's internal storage. For this you need Jumpdrive and balena Etcher or a similar image-flashing program. Jumpdrive allows your PC to write to the internal phone memory, which appears as a mass storage device when connected via USB cable.
SOFTWARE
Download Jumpdrive from GitHub: https://github.com/dreemurrs-embedded/Ju...e/releases
For flashing, use balena Etcher: https://www.balena.io/etcher/
STEPS
1) Download Jumpdrive from Github and flash it onto a microSD card
2) Insert the new Jumpdrive microSD card in your phone and reboot it
3) Plug your phone into your computer using a USB cable
4) Flash your operating system image of choice directly onto your phone's internal storage
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
  PinePhone Game Thread PixelPaintbrush 31 79,922 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 22,084 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,892 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 7,094 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 947 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,180 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,723 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,331 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,739 10-21-2025, 12:12 PM
Last Post: Richy_T
  Does PinePhone support long-term battery health optimization? roseblack 5 3,125 10-06-2025, 09:05 PM
