[12.11.20 Update] Latest PinePhone CE Manjaro - Device Arrival & Initial Tests Thread
(11-10-2020, 10:48 AM)bcnaz Wrote: On the subject of "charging"  There has been some work recently on controlling the battery heat while charging.
Perhaps this piece of the safety/control software is still in an "alpha/or beta" stage, possibly causing some of the charging issues.  ?
In the past few weeks the phone does not get as hot as it did previously.
This insight is interesting, it is good to know that the power management topic is being refined.
Yes maybe this is a safety mechanism, but if that is the case, we know that currently it surely does not work correctly - since even after the charging sequence is being stopped, it is never being resumed, even after the battery state had gone from 94% down to 86%, so surely something to be looked into by the hardware / software team.
I seem to be having some aggressive problems with my pinephone that just arrived. It is freezing after ~5-10 seconds after boot, every boot. The LED is also flashing red while it is frozen, while plugged in and not plugged in. I've tried rebooting quite a few times. After booting it goes to the screen where it is asking for my wifi password, the on screen keyboard appears, but things freeze almost immediately. No response from screen touches, and the power button doesn't turn the screen on and off. I have to long press power to turn the device off, but a reboot lands me in the same spot. Should I just try flashing from a micro sd? (the slot in the case where the OS sd should have been was empty, but I do have some at my disposal)
  Pinephone visibly losing power while plugged in Hiraghm 10 9,720 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 1,987 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,361 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,729 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 8,962 02-28-2026, 05:49 PM
Last Post: baptx
Exclamation No wIfI after Mobian update crakabeats 5 8,678 02-28-2026, 04:18 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,772 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,376 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,051 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,414 11-18-2025, 03:07 PM
