02-27-2020, 04:12 PM
Good job. The interface is more responsive than pmOS. I surely prefer it to pmOs
02-28-2020, 03:09 AM
I tested the new build leaving the phone idle overnight with WiFi and modem on. It lasted all night. The only thing is not working are the calls
photo_2020-02-28_11-21-39.jpg (Size: 118.96 KB / Downloads: 385) photo_2020-02-28_11-21-35.jpg (Size: 70.76 KB / Downloads: 382) Xfce1.jpg (Size: 66.57 KB / Downloads: 330) Just installed XFCe. I like it more and now it's look more like Linux Phone The only issue --- no keyboard at the moment
02-28-2020, 05:27 AM
(02-28-2020, 04:23 AM)harvey186 Wrote: Just installed XFCe. I like it more and now it's look more like Linux Phone Cool! Here come the follow up questions =) Which packages did you install? How did you boot in to xfce?
"- is there already a tool for overclocking it desperately?"
(02-28-2020, 05:27 AM)murak Wrote: Which packages did you install? --> I have used 'sudo apt install task-xfce-desktop'
02-28-2020, 02:29 PM
For anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
https://www.youtube.com/watch?v=6YoNuJN3Z-A
02-28-2020, 05:56 PM
(02-28-2020, 04:23 AM)harvey186 Wrote: Just installed XFCe. I like it more and now it's look more like Linux PhoneCool But just so you know, starting from the next release, there will be no display manager, you'll have to install gdm3 as well (or lightdm, should work too) (02-28-2020, 09:34 AM)nas Wrote: It appears a voltage patch needs to be applied to prevent the lcd being fried. Hopefully, the next image version will have this baked in?Yep, I've just uploaded a new kernel including this fix, you're an "apt upgrade" away from it
02-29-2020, 03:00 AM
parkerwbFor anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
But that's not a PinePhone in the video, or ??
02-29-2020, 05:03 AM
is there a difference between 'sudo apt update' and using a the latest (new) image ? Because with new image a lost all my working apps.
02-29-2020, 06:42 AM
There are a couple differences, but nothing really huge... You'll probably have to manually uninstall gdm3, but that's pretty much all
I should do a bunch of metapackages to make things better when I have some spare time. |
