Pinebook 1080p / KDE Neon freezes every 5-10 min
Hello savants,
After reinstalling "Factory Reset KDE Neon" on my Pinebook 1080P (it crashed in the middle of updating) I was in the middle of updating applications when the computer starting freezing every 5-10 minutes, requiring me to shut the system down by long-pressing the power button and pressing it again.
I found a thread in this forum tracing similar behavior back to Firefox (https://forum.pine64.org/showthread.php?tid=7690) so I removed the setting that autoloaded Firefox when KDE Neon loads ( per https://forum.pine64.org/showthread.php?tid=6443 page 3). I have tried working carefully without Firefox running, and the system still freezes.
My only major adjustments to the system's operation have been to enable it to start up without prompting for username/password, and enlarging the default font.
Any ideas what might be causing this behavior?
Thanks in advance, R.M.
(08-18-2019, 04:41 PM)pyrrhumain Wrote: Hello savants,
Is there any errors in /var/log/syslog? or any if you run dmesg?
I had freezes every 5-10 minutes. For mine pinebook, it helped to turn off sleep, dimm screen and turning screen off after idle. The screen stays always on, but no freezes afterwards. I read somewhere on this forum (or wiki), how to do it, cause in settings it's problematic, but I can't find the article now. Also I found out, that my pinebook (with KDEneon) can't use video acceleration after wake up from suspend.
(08-19-2019, 01:34 PM)jezek Wrote: I had freezes every 5-10 minutes.  For mine pinebook, it helped to turn off  sleep, dimm screen and turning screen off after idle. The screen stays always on, but no freezes afterwards. I read somewhere on this forum (or wiki), how to do it, cause in settings it's problematic, but I can't find the article now.  Also I found out, that my pinebook (with KDEneon) can't use video acceleration after wake up from suspend.
There is a lot of update recently. open the terminal and execute below two commands. Hopefully the will be resolved after update.
sudo pkcon refresh
sudo pkcon update
(reposting this here in case 'quick reply' was the wrong place)
HELLO and thanks for the replies. I apologize the the lack of response, but 1) this is a side project for me, and 2) I wanted to get some evidence before I asked for more help.
In particular, I wanted to collect the output from dmesg and /var/log/syslog from more than one incident.
I ended up collecting the last 80-100 lines of output from syslog and dmesg after each of 8 freezes. The last one happened after I executed 'pkcon refresh' and 'pkcon update' and restarted -- sorry, jezek.)
The following lines appeared consistently at the end of syslog and dmesg:
from dmesg:
[   56.366378] alloc_contig_range test_pages_isolated(a24db, a24e1) failed
[   56.366874] alloc_contig_range test_pages_isolated(a24db, a24f3) failed
[   56.728446] alloc_contig_range test_pages_isolated(a24db, a24e1) failed
[   58.901897] alloc_contig_range test_pages_isolated(a24e0, a24e7) failed
[   58.902570] alloc_contig_range test_pages_isolated(a24e0, a24f9) failed
[   58.909012] alloc_contig_range test_pages_isolated(a24e0, a24e5) failed
[   59.078407] alloc_contig_range test_pages_isolated(a24e0, a24f3) failed
[  204.989797] alloc_contig_range test_pages_isolated(a2470, a2478) failed
[  205.026480] alloc_contig_range test_pages_isolated(a246f, a2473) failed
[  298.498227] alloc_contig_range test_pages_isolated(a2848, a28ac) failed
[  307.357951] EXT4-fs (mmcblk0p1): error count since last fsck: 1
[  307.357979] EXT4-fs (mmcblk0p1): initial error at time 1565834903: ext4_find_entry:1308: inode 49104
[  307.357998] EXT4-fs (mmcblk0p1): last error at time 1565834903: ext4_find_entry:1308: inode 49104
[  662.375731] alloc_contig_range test_pages_isolated(a61e2, a66a1) failed
[  662.523852] alloc_contig_range test_pages_isolated(a24d6, a24de) failed
[  699.555663] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
[  699.563138] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  699.573680] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
[  699.581296] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  699.671793] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
[  699.679284] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  706.294158] alloc_contig_range test_pages_isolated(a2526, a255d) failed
[  709.706016] alloc_contig_range test_pages_isolated(a2552, a25af) failed
[  710.925817] alloc_contig_range test_pages_isolated(a25ad, a2639) failed
[  785.307154] alloc_contig_range test_pages_isolated(a24fb, a253b) failed
[  785.649042] alloc_contig_range test_pages_isolated(a253c, a2574) failed
[  785.661743] alloc_contig_range test_pages_isolated(a24fb, a2533) failed
[  808.632616] alloc_contig_range test_pages_isolated(a2578, a25c2) failed
[  849.056139] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
[  849.063693] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  849.118697] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
[  849.126816] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  849.365562] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
[  849.373509] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
[  849.410426] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
[  849.418281] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
from /var/log/syslog:
Aug 20 23:07:11 pyrr-pine kernel: [  662.375731] alloc_contig_range test_pages_isolated(a61e2, a66a1) failed
Aug 20 23:07:11 pyrr-pine kernel: [  662.523852] alloc_contig_range test_pages_isolated(a24d6, a24de) failed
Aug 20 23:07:49 pyrr-pine kernel: [  699.555663] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
Aug 20 23:07:49 pyrr-pine kernel: [  699.563138] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:07:49 pyrr-pine kernel: [  699.573680] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
Aug 20 23:07:49 pyrr-pine kernel: [  699.581296] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:07:49 pyrr-pine kernel: [  699.671793] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1624 bpp:32
Aug 20 23:07:49 pyrr-pine kernel: [  699.679284] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:07:56 pyrr-pine kernel: [  706.294158] alloc_contig_range test_pages_isolated(a2526, a255d) failed
Aug 20 23:07:59 pyrr-pine kernel: [  709.706016] alloc_contig_range test_pages_isolated(a2552, a25af) failed
Aug 20 23:08:00 pyrr-pine kernel: [  710.925817] alloc_contig_range test_pages_isolated(a25ad, a2639) failed
Aug 20 23:08:49 pyrr-pine ntpd[687]: 64.6.144.6 local addr 192.168.1.209 -> <null>
Aug 20 23:09:16 pyrr-pine kernel: [  785.307154] alloc_contig_range test_pages_isolated(a24fb, a253b) failed
Aug 20 23:09:16 pyrr-pine kernel: [  785.649042] alloc_contig_range test_pages_isolated(a253c, a2574) failed
Aug 20 23:09:16 pyrr-pine kernel: [  785.661743] alloc_contig_range test_pages_isolated(a24fb, a2533) failed
Aug 20 23:09:25 pyrr-pine ntpd[687]: 216.229.0.49 local addr 192.168.1.209 -> <null>
Aug 20 23:09:40 pyrr-pine kernel: [  808.632616] alloc_contig_range test_pages_isolated(a2578, a25c2) failed
Aug 20 23:10:21 pyrr-pine kernel: [  849.056139] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
Aug 20 23:10:21 pyrr-pine kernel: [  849.063693] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:10:21 pyrr-pine kernel: [  849.118697] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
Aug 20 23:10:21 pyrr-pine kernel: [  849.126816] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:10:21 pyrr-pine kernel: [  849.365562] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
Aug 20 23:10:21 pyrr-pine kernel: [  849.373509] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
Aug 20 23:10:21 pyrr-pine kernel: [  849.410426] [drm:sunxi_check_rotate_info_ok] *ERROR* 1 pitch: 1200 bpp:32
Aug 20 23:10:21 pyrr-pine kernel: [  849.418281] [drm:sunxi_rotate_commit] *ERROR* transform rotate data error.
I don't have the background to interpret any of this, but I'm hoping someone else does.
Any ideas?
Hiya, I am on:
DISTRIB_ID=neon
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="KDE neon User Edition 5.16"
on the Pinebook (not the 1080p) and seem to have similar issues.
When logged on to kdeshell the windows environment hangs while using some apps for a while.
When the windows environment hangs, I am able to switch to the virtual consoles, e.g. tty2 via ctrl-alt-F2-F6, and log in e.g. to have a look at syslog Wink but haven't been able to find sth usefull yet (need to look further).
What I wondered though if in your case your KDE neon has totally crashed or are you also able to still login via virtual console or ssh (if on)|?
Cheers.
rookieone
p.s. I am also looking for a way to recover without rebooting, which I just did, but I need to verify what I have done exactly Smile
I have this information about my system:
Operating System: KDE neon 5.16
KDE Plasma Version: 5.16.4
KDE Frameworks Version: 5.61.0
Qt Version: 5.12.3
Kernel Version: 3.10.105-bsp-1.2
OS Type: 64-bit
Processors: 4 × AArch64 Processor rev 4 (aarch64)
Memory: 1.9 GiB of RAM
Like rookieone, I can drop into a console when the GUI freezes. I was able to get the captures of syslog and dmesg,  but after that the only thing Ii knew how to do  followed by a restart 'shutdown now' followed by a restart via the power button.
My earlier response contained samples of error sequences that were consistent in eight freeze incidents. As I wrote last time: I have no idea how to interpret them, but I'm hoping someone else does.
Thanks again, R.M.
Guys, the KDE Neon build is very outdated and the kernel it ships with is no longer supported. There are so many other solid alternatives out there now ... I suggest you grab Manjaro KDE (probably best) or Armbian and don't look back.
(08-27-2019, 05:57 AM)Luke Wrote: Guys, the KDE Neon build is very outdated and the kernel it ships with is no longer supported. There are so many other solid alternatives out there now ... I suggest you grab Manjaro KDE (probably best) or Armbian and don't look back.
Last I checked, none of them has working video HW acceleration.
sudo pkcon refresh
sudo pkcon update
So far, what I've found is that if I use the commands above to update or install packages on my machine instead of using the Discovery application, my machine doesn't freeze up. It's been 12 hours and counting without issue so far.
  DietPi OS for Pinebook MichaIng 3 5,613 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 63,434 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 1,060 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 826 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 4,079 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,339 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 4,051 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,391 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,900 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,883 12-25-2020, 04:40 PM
Last Post: ford442
