boot loop with lcd plugged in
I am running Ayufan's linux bionic build. I started with bionic-minimal-pine64-bspkernel-0.7.29-138 (there was no bionic minimal for 7.30)
After fiddling with netplan (it didn't create a config file by default), manually setting DNS (was not working via DHCP), installing mate, and doing a bunch of updates I am now stuck with failing to get it running off the LCD. I edited the uEnv.txt under boot and added:
disp_screen0=lcd
but on boot it power cycles after trying to initialize the screen.
I have tried multiple 2.1a power adapters and cables but no go.  What is odd is I had the LCD working with an older image a while back with one of the same adapters and cables. Any advice?
thanks
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 7,131 05-19-2023, 07:43 AM
Last Post: crocspot
  Pine A64 does only boot with Android 5.1 Dude 6 11,459 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,587 02-23-2021, 05:33 PM
Last Post: thedu
Exclamation Can't boot when SD card inserted kivox 5 13,617 03-15-2020, 06:00 AM
Last Post: kivox
  Boot from HDD via usb BnEc 1 6,141 11-29-2019, 04:39 AM
Last Post: evilbunny
  Pine A64 stuck in boot process joey 1 5,881 05-28-2019, 09:07 PM
Last Post: joey
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 10,380 02-22-2019, 03:25 AM
Last Post: GaryFunk
  LED flashes for 1 second, board won't boot Audioslave 2 7,371 08-02-2018, 10:28 PM
  short boot time after power-up bongo 7 17,422 10-31-2017, 08:02 AM
Last Post: bongo
  No boot-up . Initializing SDRAM fail . Siim 1 5,653 09-27-2017, 04:20 PM
Last Post: dkryder
