Run Linux from hard disk
I have a RockPro64, a SATA PCI card and SATA drive. I need to have the hard disk be root for a bunch of applications I need to run. If I'm not mistaken I should be able to use initrd started from the SD card or the EMMC card to load and initrd from the hard drive and boot Linux from there. Has anyone tried this? Or perhaps there is a better way to accomplish the same thing?
(10-15-2018, 08:33 PM)linuxha Wrote: I have a RockPro64, a SATA PCI card and SATA drive. I need to have the hard disk be root for a bunch of applications I need to run. If I'm not mistaken I should be able to use initrd started from the SD card or the EMMC card to load and initrd from the hard drive and boot Linux from there. Has anyone tried this? Or perhaps there is a better way to accomplish the same thing?
At this point in time that's the best way to do it.
(10-15-2018, 08:33 PM)linuxha Wrote: Has anyone tried this?
At the moment that is the best way - same as linked here from the wiki except using NVMe.
If you stick to SDcard for initrd there are fewer complications if you switch to 4.18 or 4.19 kernel. And remove eMMC completely. Remember to keep /boot synchronised between SDcard and sda.
At some stage, when uboot is modded to load from sda (or NVMe), then the SDcard will be redundant as uboot can be put in the SPI flash.
Wow! That worked! Thanks
On the link you gave me I found this link and followed the directions. I did put a serial cable on the Pi-2 Bus to monitor what it was doing.
https://forum.frank-mankel.org/topic/208...e-platte/2
THanks for the reminder about updating the SD /boot when I do upgrades.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 770 03-25-2024, 12:12 PM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 970 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,503 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,118 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 932 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,558 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,512 01-03-2022, 10:32 AM
Last Post: whitecat23
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 3,116 07-14-2021, 02:37 PM
Last Post: TRS-80
  Booting Linux/Debian from the eMMC linuxha 4 5,261 03-02-2021, 07:01 PM
Last Post: linuxha
  Xen EFI with Alpine Linux dom0 sir.lami 0 2,524 08-26-2020, 12:25 PM
Last Post: sir.lami
