Please try Slackware Arm Current on Rock64!
This will be a set of scripts I have been using to create a disk image and public images I have created off the current rock64 ayufan kernel and combined with Slackware Arm Current.
Install Instructions:
  1. Download the latest slackware armhf release https://github.com/mwiljanen/slackrock/releases
  2. As a privileged user please run: zcat slackware-current-minimal-rock64-0.5.10-118-armhf.img.gz | sudo dd of=/dev/sdX bs=4M status=progress
  3. I have not created a script to autoexpand the drive so this must be done with gparted.
  4. After boot you can login with user user: rock64 and pass: rock64 this user has sudo access.
  5. To get this image on the internet you must use ifconfig or dhcpcd with an ethernet cable, Network manager is not installed on the slackware-minimal rootfs.
  6. After you get a connection to the internet now you can install all the packages, but do not install the slackwarearm-current kernels, you can blacklist these in the /etc/slackpkg/blacklist. If you install this kernel your rock64 will refuse to boot. To upgrade do these steps:
  • slackpkg update
  • slackpkg install-new
  • slackpkg upgrade-all
This upgrade will take over an hour or more, so please be patient and if you do the full install it will be about +9GB of space on your SD card so a 16GB card is not recommended for a full install.
Now you can enjoy slackware on you Rock64!
Enjoy!
mwiljanen
Thanks for this Smile
Nice work, thanks!
Thank for the great responses, I am very glad to be using Ayufan's kernel with a distro I have been using for years, thanks for the support!
Hi, thanks for the Slack. I've tried using the rock64 - rock64 user and password but it's failing to authenticate. :-(
Sorry. I switched to console and found what I needed. Thanks
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,176 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 2,260 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,316 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,306 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,270 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,369 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,558 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,495 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 88,356 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 111,579 09-01-2024, 06:05 AM
