booting android
is it possible to boot android from a usb hard drive or are we limited to the emmc/sd card? do i need a u-boot file separate from the linux one?
(02-09-2018, 01:47 PM)dan1972 Wrote: is it possible to boot android from a usb hard drive or are we limited to the emmc/sd card? do i need a u-boot file separate from the linux one?
I assume you mean boot using uboot on SPI ? Not yet, but ayufan said some time back that he will try to have his android support SPI booting in the future.
if there isnt a u-boot option yet is it possible to boot from SD into usb as with linux? i dont have a emmc module yet.
(02-10-2018, 09:06 AM)dan1972 Wrote: if there isnt a u-boot option yet is it possible to boot from SD into usb as with linux? i dont have a emmc module yet.
I think the answer is no, but I suggest you ask ayufan directly in IRC.
  Android Images (ROCK64) pineadmin 76 170,963 05-13-2024, 04:13 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 6,579 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,571 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,231 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,733 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,156 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,638 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,226 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,688 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,883 09-18-2020, 07:58 PM
Last Post: BowerR64
