Rock64 charger availability
I just received my Rock64 and I thought I had also ordered a power adapter (UK), but I didn't and checking my order I didn't actually order one.  If I buy one through the store here then the shipping from China will cost more than the product itself. However I can't a single 3.5mm barrel charger (5V, 3A) in online in the UK, it seems to be a very strange type of power cable.
Does anyone have idea where to get one in the UK?
I have found some USB to 3.5mm barrel charger, so if I found a USB plug which is 5v 3A would that work?
You have two possible options.
You could go with an adapter like this (best quality one I found on a cursory search of amazon.co.uk), or you could go with the USB-to-3.5mm cable.
Whatever you go with, make sure its connector is 3.5x1.35mm, and the cable is fairly thick. Thin cables will cause voltage drop and seemingly random issues under load.
Unless you live in West London - buy me a pint I give you a charger Wink
How did you find that on amazon I spent ages trying to find the correct size plug which was also 3A (not 2A)
Thanks Luke, il try the amazon cable but if that doesn’t work then I’ll take you up on the offer (I’m in north London so it’s a bit of a trek to west london)
(08-18-2017, 04:57 AM)jon889 Wrote: How did you find that on amazon I spent ages trying to find the correct size plug which was also 3A (not 2A)
Fire219 used clever search parameters "power+adapter+5v+3a+3.5mm" Smile
  Are HW design files available for ROCK64? irenek 3 5,272 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 398 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,165 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 670 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,523 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,866 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,632 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,757 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,933 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,261 09-28-2021, 03:07 PM
Last Post: TRS-80
