Rufus for SD card writing from Windows
Smile
Hi everyone, not sure anyone's posted about this yet, so I just wanted to say I've had great success installing Android images to SD cards using Rufus, the utility recommended by Ubuntu for creating bootable USB drives.  Turns out it supports dd images, so no need to mess with Phoenix or actually run dd in linux.  FWIW, I was using Rufus on Windows 10 with my laptop's built-in SD card slot.
I first validated the cards using the tester recommended on the wiki (H2testw), then imaged them with Rufus.  Validation and imaging took a very long time, probably because I have a crappy SD writer, but as a result pine64 boots into Android as quickly as my phone. Big Grin
(06-08-2016, 11:36 AM)psmacmur Wrote: Hi everyone, not sure anyone's posted about this yet, so I just wanted to say I've had great success installing Android images to SD cards using Rufus, the utility recommended by Ubuntu for creating bootable USB drives.  Turns out it supports dd images, so no need to mess with Phoenix or actually run dd in linux.  FWIW, I was using Rufus on Windows 10 with my laptop's built-in SD card slot.
Thanks for the post psmacmur Smile
However, just so as to not confuse ppl: Phoenix card cannot be used to burn dd images in case someone misreads psmacmur
  How to boot from SD card on pinebook pro linux123 3 10,540 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,227 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,296 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,470 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 305,349 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 19,144 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,345 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 6,240 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,219 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 38,373 09-22-2016, 06:28 AM
Last Post: tkaiser
