Slow Teathering With PinePhone
(10-07-2022, 02:00 PM)treebeard Wrote: There are various posts suggesting some nftables magic can change the TTL to evade the sniffing but I haven't been able to get that to work.
For what it's worth, I did find a way to "fix" the TTL but it was not enough to avoid Verizon's tether-block.  After starting tether (or hotspot) do
sudo nft add rule ip nm-shared-usb0 filter_forward index 0 ip saddr 10.42.0.0/24 iifname "usb0" ip ttl set 64 accept
This will make the filter_forward chain look like:
chain filter_forward {
    type filter hook forward priority filter; policy accept;
    ip daddr 10.42.0.0/24 oifname "usb0" ct state { established, related } accept
    ip saddr 10.42.0.0/24 iifname "usb0" accept
    iifname "usb0" oifname "usb0" accept
    iifname "usb0" reject
    oifname "usb0" reject
... where rule #3 becomes redundant but harmless.  This is quite a bit different than the other techniques I ran across, and perhaps it's not the best approach.  I leave it here in case someone else finds it useful.
  Pinephone software Csanderson0313 3 1,181 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 83,984 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,428 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,095 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,062 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,458 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,898 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,484 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,969 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 7,959 10-21-2025, 12:12 PM
Last Post: Richy_T
