Phone bricked after update. Won't boot
Hello all,  after running the pinephonepro-post install script, I was able to update the phone with the latest repositories.  After the upgrade, i restarted my phone to make sure everything was good to go, and the phone never turned back on.  It has been completely dead since, and I have tried several of the tricks on the forum to see if I could get it to boot up.  It had about 50% power when it went down.  It was completely done with the update as well.  Not sure why a simple reboot would brick the phone.  Anyways, Any help would be appreciated. Thanks in advance
Try to charge the phone, maybe try a sd card with an OS flashed to it..?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Have you tried to boot on a SD card holding the RE button to bypass the eMMC? As explained here: https://wiki.pine64.org/wiki/PinePhone_P...g_the_eMMC
(02-02-2022, 05:59 PM)mando Wrote: Hello all,  after running the pinephonepro-post install script, I was able to update the phone with the latest repositories.  After the upgrade, i restarted my phone to make sure everything was good to go, and the phone never turned back on.  It has been completely dead since, and I have tried several of the tricks on the forum to see if I could get it to boot up.  It had about 50% power when it went down.  It was completely done with the update as well.  Not sure why a simple reboot would brick the phone.  Anyways, Any help would be appreciated. Thanks in advance
In particular which tricks have you tried? It'll help narrow things down.
AH  !
I have the same symptoms  ===> however my Explorer phone IS booting.
The boot indicator LED is not activating...  I posted this on the Bookworm thread.
Start with a normal 2 second power button press,  then just wait,  maybe up to 2+ minutes,
IT is Hard to just wait when you are looking at a black screen.  ===> Eventually the lock screen shows up.
IF the phone is on --- but froze from a suspend fault ---  a 12 second press on power button ---  then wait about 60 seconds for the lock screen.
A Few bugs, but over-all,   the new Explorer with Bookworm on sd card is running fairly well,
I used it to surf the forum and write a few posts a day or so back, --  I even used the cell data.
IT DOES SUCK ===>   THAT BOOT INDICATOR LIGHT IS NOT WORKING   Exclamation
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Hi  @mando
Did you ever resolve this problem ?
Which operating system are you using ?
( could it be your boot indicator light is not functioning ? )
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 922 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,586 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 1,070 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 5,162 10-27-2023, 12:46 AM
Last Post: gregb49
  PinePhone not booting after interrupting update PineBetter 1 1,128 05-31-2023, 04:37 AM
Last Post: alaraajavamma
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,664 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,496 01-25-2023, 04:38 PM
Last Post: emsyr
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,341 12-31-2022, 09:14 AM
Last Post: mburns
  Current State of PIne Phone Pro kmsgli 40 26,967 12-23-2022, 06:44 PM
Last Post: Simon Belmont
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 3,067 11-20-2022, 05:58 AM
Last Post: wibble
