10-20-2021, 11:25 PM
The Beta version of Manjaro ARM w/ Phosh I'm running crops the screen awkwardly on the settings menu, which means I'm unable to update my device.
I assume I can update the device via a command line using Terminal.
What command/string do I need to type in to update all packages?
Thanks in advance
Thanks in advance
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube
