Built-in Webcam Not Working
(06-07-2020, 07:09 AM)Opvolger Wrote:
(05-29-2020, 01:13 PM)fozzedout Wrote:
(05-28-2020, 07:49 PM)xmixahlx Wrote: check if your user is added to the video group
dmesg|grep video
if not detected, toggle the privacy hardware disable and reboot
dmesg again
the camera works, but is not great
Yes, my user is added to the video group.
Here is my dmesg output (doesn't change if the privacy switch is enabled or disabled):
$ dmesg|grep video
[    0.000000] Kernel command line: initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=LABEL=ROOT_MNJRO rw rootwait video=eDP-1:1920x1080@60 video=HDMI-A-1:1920x1080@60 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
[    0.276266] videodev: Linux video capture interface: v2.00
[    8.459274] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[    8.472188] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    8.472803] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[    8.472906] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
As you can see - only video 0, 1 and 2 are detected
[opvolger@pine64 ~]$ dmesg|grep video
[    0.286198] videodev: Linux video capture interface: v2.00
[    6.521834] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[    6.527476] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[    6.530597] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[    6.530769] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[    8.693178] uvcvideo: Found UVC 1.00 device USB Camera (0c45:6321)
[    8.729161] uvcvideo 2-1.2:1.0: Entity type for entity Extension 4 was not initialized!
[    8.729175] uvcvideo 2-1.2:1.0: Entity type for entity Processing 3 was not initialized!
[    8.729182] uvcvideo 2-1.2:1.0: Entity type for entity Camera 1 was not initialized!
[    8.730958] usbcore: registered new interface driver uvcvideo
output of a working webcam. (is the same).
I received my laptop this week. Only had problems with WIFI (so was turned off, privacy switch). My webcam works.
https://wiki.pine64.org/index.php/Pinebo...y_Switches <- switches. i had to reboot.
For those with working webcams, would you be able to check which modules you have loaded and post on this forums pls?
lsmod
Would be a good starting point to compare outputs.
Thank you so much!
Built-in Webcam Not Working - by fozzedout - 05-28-2020, 06:35 PM
RE: Built-in Webcam Not Working - by xmixahlx - 05-28-2020, 07:49 PM
RE: Built-in Webcam Not Working - by fozzedout - 05-29-2020, 01:13 PM
RE: Built-in Webcam Not Working - by Opvolger - 06-07-2020, 07:09 AM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-09-2020, 03:29 AM
RE: Built-in Webcam Not Working - by diodelass - 05-28-2020, 09:25 PM
RE: Built-in Webcam Not Working - by charlespine - 05-28-2020, 10:49 PM
RE: Built-in Webcam Not Working - by Nora No - 05-31-2020, 04:09 AM
RE: Built-in Webcam Not Working - by Jazzband - 06-06-2020, 10:45 PM
RE: Built-in Webcam Not Working - by xmixahlx - 06-07-2020, 01:55 AM
RE: Built-in Webcam Not Working - by Jazzband - 06-07-2020, 11:24 AM
RE: Built-in Webcam Not Working - by xmixahlx - 06-07-2020, 01:43 PM
RE: Built-in Webcam Not Working - by Jazzband - 06-07-2020, 04:27 PM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-08-2020, 07:50 AM
RE: Built-in Webcam Not Working - by xmixahlx - 06-08-2020, 09:51 AM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-08-2020, 11:24 AM
RE: Built-in Webcam Not Working - by Opvolger - 06-09-2020, 04:29 PM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-10-2020, 12:07 PM
RE: Built-in Webcam Not Working - by firefox-58 - 06-16-2020, 09:31 AM
RE: Built-in Webcam Not Working - by Jazzband - 06-16-2020, 02:21 PM
RE: Built-in Webcam Not Working - by firefox-58 - 06-17-2020, 03:44 AM
RE: Built-in Webcam Not Working - by tllim - 06-20-2020, 04:24 PM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-21-2020, 08:12 AM
RE: Built-in Webcam Not Working - by tllim - 06-26-2020, 03:04 PM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-17-2020, 06:52 AM
RE: Built-in Webcam Not Working - by firefox-58 - 06-17-2020, 11:13 AM
RE: Built-in Webcam Not Working - by lemaurien19 - 06-20-2020, 07:52 AM
RE: Built-in Webcam Not Working - by Ecampos - 07-02-2020, 06:33 PM
RE: Built-in Webcam Not Working - by erock22 - 07-13-2020, 09:46 PM
RE: Built-in Webcam Not Working - by Jazzband - 07-14-2020, 09:18 AM
RE: Built-in Webcam Not Working - by erock22 - 07-17-2020, 09:11 PM
RE: Built-in Webcam Not Working - by Jazzband - 07-18-2020, 12:41 PM
RE: Built-in Webcam Not Working - by erock22 - 07-14-2020, 08:44 PM
RE: Built-in Webcam Not Working - by xmixahlx - 07-14-2020, 11:08 PM
RE: Built-in Webcam Not Working - by erock22 - 07-15-2020, 07:50 PM
RE: Built-in Webcam Not Working - by rimaille - 07-15-2020, 03:51 AM
RE: Built-in Webcam Not Working - by lemaurien19 - 02-01-2021, 08:59 AM
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 796 12-09-2022, 04:48 PM
Last Post: River
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 2,460 06-29-2022, 02:00 PM
Last Post: Chief
Sad Webcam not working in pinebook pro with Manjaro jcarball 2 3,213 04-28-2021, 03:23 PM
Last Post: jcarball
  [split] U-Boot with NVMe support, keyboard & display working as400 83 84,221 01-27-2021, 12:48 AM
Last Post: as400
  webcam photo solid gray stozi 0 1,566 01-05-2021, 05:35 PM
Last Post: stozi
  Booting to sdcard stopped working after emmc flash techiedog 3 4,006 12-31-2020, 06:30 PM
Last Post: Anarethos
  Needed basic Info on using Webcam on PBP User 17828 6 6,805 12-18-2020, 07:24 PM
Last Post: Arwen
  Wifi stopped working after updates pineitup 10 11,275 11-07-2020, 02:59 AM
  Working terminal emulator bookguy1 7 9,424 08-04-2020, 02:34 PM
Last Post: mfashby
  Suspend with NVME not working - Default Debian appdev46 5 8,789 07-14-2020, 01:53 PM
Last Post: Jeremiah Cornelius
