A Few Issues After OTA-12 Update
(05-14-2020, 11:08 AM)MIchael Wrote: I've updated to Channel in Update Settings to Development (top one) and it's running like a champ. It's on Ubuntu Touch Version 24 dated 13 May. It now sees a sim card which is new and Wifi doesn't vanish requiring a reload... You can restart and it will connect to the saved connection.
Odd, I was able to boot into the system earlier, checked the dev channel again, and was able to get the update. The update installed, and the phone rebooted. It seemed to work fine for a few minutes until I went into the OpenStore to grab some applications, and then the phone killed itself again.
Now we're back to the Pine64 splash screen followed by a constant black screen that doesn't boot into UT. Perhaps I'll try to re-download the newest build and attempt another flash on the SD card to see if that fixes the issue, though I'll have to grab the update again afterwards.
A Few Issues After OTA-12 Update - by falkensmaze - 05-14-2020, 09:53 AM
RE: A Few Issues After OTA-12 Update - by MIchael - 05-14-2020, 11:08 AM
RE: A Few Issues After OTA-12 Update - by falkensmaze - 05-14-2020, 12:31 PM
  PinePhone and PinePhone Pro 20.04 Focal Install and Update c3l@ 0 747 05-12-2023, 05:06 AM
Last Post: c3l@
  How to find out about package versions on different update channels? kqlnut 0 1,687 08-30-2021, 01:38 PM
Last Post: kqlnut
  What does an OTA Update look like lsitongia 0 1,582 08-24-2021, 10:20 AM
Last Post: lsitongia
Sad Help! - Screen blank after update. Zweitaktmotor 4 4,567 07-26-2021, 05:17 PM
Last Post: Zweitaktmotor
  Update Channels & Kernel Version mark1250 2 3,237 03-20-2021, 08:26 AM
Last Post: mark1250
  Kernel update failing issues KNERD 5 6,791 01-10-2021, 01:49 PM
Last Post: KNERD
  Kernel Update Channel Zweitaktmotor 2 3,797 01-06-2021, 08:22 PM
Last Post: Korac
  Update process getting more buggy. Cree 0 1,892 08-26-2020, 12:43 AM
Last Post: Cree
  Update Python and get gcc? sunnystormy 2 3,556 08-10-2020, 09:04 AM
Last Post: sunnystormy
  Tutorial for new UBPorts CE users / list of known issues? ThatGeoGuy 2 4,810 07-21-2020, 05:54 PM
Last Post: natasha
