4pin Connector for dual SATA
I'm wondering if the CON15 could also be used as the DC IN, of course the normal Jack should not be connected then.
Does anyone has any hint on this?
Martin
4pin Connector for dual SATA - by m.ekstrom - 05-07-2020, 02:32 AM
RE: 4pin Connector for dual SATA - by tllim - 05-09-2020, 07:55 PM
RE: 4pin Connector for dual SATA - by mabs - 05-14-2020, 02:33 AM
RE: 4pin Connector for dual SATA - by mabs - 07-28-2020, 07:07 AM
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 120,651 09-25-2023, 12:46 AM
Last Post: ChriChri
  Sata HD stopped booting db579 2 2,204 03-11-2022, 03:34 PM
Last Post: db579
  Dual Monitor Setup cmodernel004 3 6,413 03-08-2021, 06:02 PM
Last Post: Mangled
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,786 02-11-2021, 10:18 AM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,756 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,669 10-18-2020, 08:05 PM
Last Post: revoman
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 14,138 02-19-2020, 09:08 AM
Last Post: fysa
  DSI connector is 30 pins NOT 32 ( be aware) AmroIb 3 4,912 05-25-2019, 06:15 AM
Last Post: dukla2000
  Usb3 to sata and USB C to sata / openmedia RockPro64Newbie 1 2,734 01-19-2019, 04:45 PM
Last Post: oreggin
  NAS Box - fdisk not showing hard-drives w/pcie sata card dkebler 0 1,935 10-12-2018, 12:30 PM
Last Post: dkebler
