Usb3 to sata and USB C to sata / openmedia
If I connect sata 2.5" SSD 500gb to USB3 port
And
I connect USB C to sata 2.5 SSD 500gb
Running openmediavault.
 Can I set up the 1TB storage (2 x 500GB SSDs) as NAS?  If so can I set up raid copy to 2nd drive?
I've seen ROCKPORT 64 setup with 1 drive with Openmediavault as a successful NAS.
Thank you in advance!
This is a good question. I trying almost the same with two of JMicron JMS551 SATA3 dual port docking station with four SATA HDD. Two HDD on both USB3-A and USB3-C ports. I use Arch linux with Mainline kernel (4.20.3-1-ARCH) and a little trick was needed to get USB-C to work as it is in OTG mode by default and needed to change to host mode:
"fdtput -t s /boot/dtbs/rockchip/rk3399-rockpro64.dtb /usb@fe800000/dwc3 dr_mode host"
After reboot the second docking station is working but it is not USB3 but USB2 (Bus #5):
[oreggin@nas ~]$ lsusb -t
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
   |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
   |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
[oreggin@nas ~]$
I use this cable between RockPro64 USB-C port and docking station USB3-B port: https://www.conrad.com/ce/en/product/142...connectors
Any idea how to make it work in USB3 mode?
Thanks!
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,214 09-25-2023, 12:46 AM
Last Post: ChriChri
  Second USB3 port as OTG softsr 1 1,136 05-31-2022, 09:08 AM
Last Post: softsr
  Sata HD stopped booting db579 2 2,163 03-11-2022, 03:34 PM
Last Post: db579
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,690 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,602 10-18-2020, 08:05 PM
Last Post: revoman
  4pin Connector for dual SATA m.ekstrom 4 6,186 07-28-2020, 07:07 AM
Last Post: mabs
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 14,024 02-19-2020, 09:08 AM
Last Post: fysa
  USB3 and USB-C sharing bus? erols 1 2,874 07-08-2019, 08:56 PM
  NAS Box - fdisk not showing hard-drives w/pcie sata card dkebler 0 1,915 10-12-2018, 12:30 PM
Last Post: dkebler
  Dual SATA-II Interface Card question and NAS question RockPro64Newbie 5 5,925 08-17-2018, 10:58 PM
Last Post: RockPro64Newbie
