NAS Box - fdisk not showing hard-drives w/pcie sata card
Just getting my new pine64 NAS box up and running.
I've got the ayufan latest stable image loaded and running no issues (18.04 ubuntu).
I have the pcie sata card I bought from pine64.
I have them connected to two 3.5" Hitachi drives
The drives are powered and I did see a momentary light flash on the card but when I do a fdisk -L neither drive is listed.
Given all the hardware looks good does the ayufan built kernel not include that pcie board?
Why can't I see these drives?
hmm.   if I just cat dev/disks/by-id   I see them sda/sbd
Well something changed after a reboot I see the drives with fdisk now so ......nevermind Confused
rock64@rockpro64:/dev/disk/by-id$ ll
total 0
drwxr-xr-x 2 root root 280 Oct 12 17:17 ./
drwxr-xr-x 8 root root 160 Jan 18  2013 ../
lrwxrwxrwx 1 root root   9 Oct 12 17:17 ata-Hitachi_HUA723020ALA641_YFGPRJ9A -> ../../sda
lrwxrwxrwx 1 root root   9 Oct 12 17:17 ata-Hitachi_HUA723020ALA641_YFH93KTD -> ../../sdb
lrwxrwxrwx 1 root root  13 Oct 12 17:17 mmc-NCard_0x82f69016 -> ../../mmcblk1
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part1 -> ../../mmcblk1p1
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part2 -> ../../mmcblk1p2
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part3 -> ../../mmcblk1p3
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part4 -> ../../mmcblk1p4
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part5 -> ../../mmcblk1p5
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part6 -> ../../mmcblk1p6
lrwxrwxrwx 1 root root  15 Oct 12 17:17 mmc-NCard_0x82f69016-part7 -> ../../mmcblk1p7
lrwxrwxrwx 1 root root   9 Oct 12 17:17 wwn-0x5000cca223c9e05a -> ../../sda
lrwxrwxrwx 1 root root   9 Oct 12 17:17 wwn-0x5000cca223d23c42 -> ../../sdb
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 116,526 09-25-2023, 12:46 AM
Last Post: ChriChri
  PCIE interface power on too late Slark Xiao 0 958 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Sata HD stopped booting db579 2 2,075 03-11-2022, 03:34 PM
Last Post: db579
  PCIe gen1 timeout - how to debug tosi 3 4,450 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 1,702 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 1,731 02-11-2021, 10:18 AM
Last Post: LMM
  PCIe Armbian and Ayufan for nvme ssd LMM 1 2,625 02-03-2021, 04:38 PM
Last Post: LMM
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 2,868 10-25-2020, 07:42 PM
Last Post: MSteam
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 5,584 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 7,478 10-18-2020, 08:05 PM
Last Post: revoman
