Mainline Debian Buster on RockPro64 ?
#29
(11-15-2020, 05:46 AM)kuleszdl Wrote: This rather looks like an issue with the DTB file to me since that's what the "loading fdt" is about. Did you try to replace the dtb file with a version from an earlier kernel? Since there are two rockpro64 dtbs that are linked - did you make sure you have both in your dtb directory?
Afair, I used kernel 5.6 and later 5.7 when writing my guide but I didn't use or upgrade my rockpro64 since then (I use the installation on other boards as I find the rockpro64 too power-hungry).
Edit: Double-checked - I can confirm the current kernel in Debian/Devuan unstable is 5.9 now, I will try to see how it works for me.
Edit 2: Kernel 5.9 boots fine (on the pinebook pro), however I have issues with the sdcard. Not sure whether this might be a hardware issue though.
Ah! No, I didn't try that. Come to think of it, I only put one of them in the dtb directory. In that case, I guess your image works fine. I still have it on my other computer, I'll try to check with a different SD-card when I have time.
What issues do you have with the SD-card?
The board works fine for me right now, it powers a small webserver with a couple of other services. I'm actually very impressed with it as compared to the RPi's I've toyed with before.
RE: Mainline Debian Buster on RockPro64 ? - by n4tter4ngell - 11-17-2020, 04:32 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 562 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 753 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,690 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,669 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,030 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 612 05-21-2023, 11:34 PM
Last Post: shpark
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 581 04-23-2023, 11:02 PM
Last Post: Thisone
  Rockpro64 Dead on arrival? quixoticgeek 1 988 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,635 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,714 01-03-2023, 06:53 PM
Last Post: raph
