2020-02-20 Plasma Mobile image
#41
(03-02-2020, 05:53 AM)PureTryOut Wrote:
(03-01-2020, 05:38 PM)edge Wrote: The xsession error file contained only one line: "Error relocating /usr/bin/startplasma-wayland: _ZN22QDBusAbstractInterface6doCallEN5QDBus8CallModeERK7QStringPK8QVariantm: symbol not found".
Also, what is needed to be able to ssh to the device? The IP shows up when connected via USB, but a connection refused error message is the result of the ssh command.
I know you said you upgraded, but could you make absolutely sure? ;p That startup error just shouldn't happen with a fully upgraded system.
For ssh, are you sure you connect to the right IP? It works for everyone else.
Tried starting with the base image and upgrading again yesterday. Have the same error in .xsession-errors. There was a warning that tail was not able to find something, but the exit code of upgrade --available was apparently 0 as it proceeded to the chained reboot command. Huh
2020-02-20 Plasma Mobile image - by MartijnBraam - 02-20-2020, 03:13 PM
RE: 2020-02-20 Plasma Mobile image - by greyskies - 02-20-2020, 03:30 PM
RE: 2020-02-20 Plasma Mobile image - by greyskies - 02-20-2020, 07:39 PM
RE: 2020-02-20 Plasma Mobile image - by rmgr - 02-21-2020, 02:34 AM
RE: 2020-02-20 Plasma Mobile image - by Alho - 02-21-2020, 03:46 PM
RE: 2020-02-20 Plasma Mobile image - by p1trson - 02-22-2020, 08:14 AM
RE: 2020-02-20 Plasma Mobile image - by hk135 - 02-24-2020, 09:28 AM
RE: 2020-02-20 Plasma Mobile image - by hk135 - 02-25-2020, 03:44 AM
RE: 2020-02-20 Plasma Mobile image - by sundog - 02-26-2020, 05:17 PM
RE: 2020-02-20 Plasma Mobile image - by wibble - 02-26-2020, 07:55 AM
RE: 2020-02-20 Plasma Mobile image - by quixote - 02-27-2020, 12:05 AM
RE: 2020-02-20 Plasma Mobile image - by quixote - 02-27-2020, 11:36 AM
RE: 2020-02-20 Plasma Mobile image - by wibble - 02-27-2020, 05:49 AM
RE: 2020-02-20 Plasma Mobile image - by sundog - 02-27-2020, 09:43 AM
RE: 2020-02-20 Plasma Mobile image - by Huitsi - 02-27-2020, 01:41 PM
RE: 2020-02-20 Plasma Mobile image - by quixote - 02-27-2020, 08:26 PM
RE: 2020-02-20 Plasma Mobile image - by quixote - 02-28-2020, 11:52 AM
RE: 2020-02-20 Plasma Mobile image - by p1trson - 03-01-2020, 06:22 AM
RE: 2020-02-20 Plasma Mobile image - by p1trson - 03-01-2020, 08:22 AM
RE: 2020-02-20 Plasma Mobile image - by p1trson - 03-01-2020, 02:29 PM
RE: 2020-02-20 Plasma Mobile image - by Luke - 03-01-2020, 02:32 PM
RE: 2020-02-20 Plasma Mobile image - by edge - 03-01-2020, 05:38 PM
RE: 2020-02-20 Plasma Mobile image - by edge - 03-04-2020, 10:38 AM
RE: 2020-02-20 Plasma Mobile image - by p1trson - 03-02-2020, 01:16 PM
RE: 2020-02-20 Plasma Mobile image - by noeman5 - 03-02-2020, 10:16 PM
  Gnome mobile user641 1 649 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 1,202 12-03-2023, 07:54 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 803 10-03-2023, 06:32 PM
Question Always Use Mobile Data DingDangDoong 4 1,906 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,408 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,177 11-06-2022, 06:41 PM
Last Post: Chief
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,318 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 2,024 03-23-2021, 10:25 AM
Last Post: Egolep
  Where is the original PM OS image for Pinephone? mw4jet 1 2,631 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,728 02-28-2021, 02:20 PM
Last Post: MtnSk8
