NextCloud Gnome Mobile
Karlender does not connect to my Nextcloud, and also the file browser does not show andy files on my cloud. In preferences, Nextcloud is set to show contacts, calendars, and files.
(09-01-2023, 01:11 AM)Uturn Wrote: Karlender does not connect to my Nextcloud, and also the file browser does not show andy files on my cloud. In preferences, Nextcloud is set to show contacts, calendars, and files.
You have to login inside Karlender app - the login from system settings does not connect automatically.
To see files you have to install Nautilus (portfolio does not work)
My Problem with Karlender App is that it syncs forever since install, and adding my nextcloud credentials changes nothing. This Karlender syncs and syncs and shows zero connected calendars.
(09-06-2023, 03:32 AM)Uturn Wrote: My Problem with Karlender App is that it syncs forever since install, and adding my nextcloud credentials changes nothing. This Karlender syncs and syncs and shows zero connected calendars.
Maybe you can try gnome-calendar? It should work and also it will sync the connection directly from the system settings.
You need to "scale-to-fit" gnome-calender because it does not scale perfectly.
Also if you have 2fa in your account you might need to generate app password
thank you, gnome-calendar works super.
  Gnome mobile user641 1 648 01-06-2024, 11:06 AM
Last Post: Uturn
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 800 10-03-2023, 06:32 PM
  Software app in postmarket gnome shell Uturn 1 621 09-06-2023, 05:27 AM
Last Post: alaraajavamma
Question Always Use Mobile Data DingDangDoong 4 1,904 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & No MMS X0X0X0X0X0 1 1,406 11-07-2022, 10:34 PM
Last Post: X0X0X0X0X0
  PostmarketOS v22.06 Plasma Mobile on PinePhone Pro & WiFi Connect to SSID X0X0X0X0X0 1 1,176 11-06-2022, 06:41 PM
Last Post: Chief
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,315 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  gnome-firmware-updater not found (mirrors) wizardry 1 1,430 03-22-2022, 12:30 PM
Last Post: wizardry
  [PostmarketOS with Plasma Mobile] Angelfish adblock + wpa supplicant time out Egolep 0 2,021 03-23-2021, 10:25 AM
Last Post: Egolep
  Angelfish on Plasma Mobile not working fernando_c_m 4 6,101 09-06-2020, 10:31 PM
Last Post: bcnaz
