Case defect (crack)
I contacted sales@pine64.org asking to purchase a replacement lower case assembly. They obliged, and I was able to switch from an ISO keyboard to an ANSI keyboard in the process. So far the new case has been holding up fine. (My lesson learned: don't lose screws.)
Edit: If you do this sort of swap, be prepared to flash a new keyboard firmware. The keyboard controller firmware is on the main board, and the ISO firmware does not work with the ANSI keyboard or vice versa. You'll need SSH access or an external keyboard.
Case defect (crack) - by bigCamel - 02-18-2020, 03:11 PM
Case defect (crack) - by jabo - 02-18-2020, 03:47 PM
RE: Case defect (crack) - by Solra Bizna - 02-18-2020, 11:17 PM
RE: Case defect (crack) - by hdk - 02-19-2020, 12:46 AM
RE: Case defect (crack) - by TDC_PBP - 04-17-2020, 01:04 PM
Case defect (crack) - by tophneal - 02-19-2020, 11:47 AM
RE: Case defect (crack) - by moonwalkers - 03-11-2020, 02:50 PM
RE: Case defect (crack) - by josmo - 03-11-2020, 03:21 PM
RE: Case defect (crack) - by Solra Bizna - 03-13-2020, 01:56 AM
RE: Case defect (crack) - by josmo - 03-13-2020, 09:24 AM
RE: Case defect (crack) - by Solra Bizna - 03-14-2020, 01:01 AM
RE: Case defect (crack) - by TDC_PBP - 04-16-2020, 12:44 PM
RE: Case defect (crack) - by jabo - 03-13-2020, 05:01 AM
Case defect (crack) - by Wizzard - 03-15-2020, 11:54 AM
RE: Case defect (crack) - by cmelcher - 03-24-2020, 03:57 PM
RE: Case defect (crack) - by xmixahlx - 03-24-2020, 11:05 PM
RE: Case defect (crack) - by hdk - 04-17-2020, 11:47 PM
RE: Case defect (crack) - by Solra Bizna - 04-19-2020, 03:54 AM
RE: Case defect (crack) - by mtlemmonrunner - 04-19-2020, 08:06 PM
RE: Case defect (crack) - by bcnaz - 04-19-2020, 09:15 PM
RE: Case defect (crack) - by bigCamel - 04-27-2020, 06:48 AM
RE: Case defect (crack) - by TDC_PBP - 04-27-2020, 08:12 AM
RE: Case defect (crack) - by vfr400racer - 04-29-2020, 01:04 PM
RE: Case defect (crack) - by bigCamel - 08-13-2020, 04:03 PM
RE: Case defect (crack) - by tllim - 08-13-2020, 09:18 PM
RE: Case defect (crack) - by bigCamel - 08-18-2020, 03:41 PM
  Suggested software for use case ehcorn 4 2,120 08-17-2022, 04:06 PM
Last Post: TRS-80
  Screws on bottom case coming loose quadrantids 8 7,422 01-20-2021, 03:47 AM
Last Post: quadrantids
  Pinebook Pro Case models sundog 2 2,897 11-05-2020, 09:31 AM
Last Post: sundog
  Minor case damage with gentle use. (Is anyone else seeing this?) hikaricore 31 35,755 10-26-2020, 10:19 PM
Last Post: hikaricore
  Got a case for my Pinebook Pro GhostDragon 3 4,298 09-24-2020, 07:24 PM
Last Post: bastafari
  Case upgrade for my PBP robt 2 3,893 08-08-2020, 04:35 PM
Last Post: Damon
Photo No case logo? No problem! ALBNC1974 6 7,708 06-04-2020, 07:48 PM
Last Post: Dendrocalamus64
