wasp-os: MicroPython for PineTime!
#35
(06-01-2020, 08:43 PM)VMMainFrame Wrote:
(06-01-2020, 03:48 AM)danielt Wrote: Strange... so in summary everything appears to work perfectly! Thus it is *very* strange the watch doesn't show the UI automatically at boot.
I guess as a final check you should use cat('/flash/main.py') to make sure that the contents of main.py are correct. Perhaps you could also confirm that you are not acidentally booting into safe mode are you (if you have the button pressed when the pine cone disappears to the final time then the watch will enter safe mode and skip the startup file).
I issued the cat command and an ls command and the results are confusing, considering the information I previously provided.
Yes, confusing indeed.
I think to get to the bottom of this I think I'll need to change to the code to boot.py to get some more information out. IIRC you were using the 0.2 release... are you compiling yourself or working just with the binary release? Just wondered if I should share patches or .zip file?
PS Since we're getting to the point of throwing code around this might also be a good point to migrate the discussion to the github issue tracker for wasp-os? Attachments work out better there...
wasp-os: MicroPython for PineTime! - by danielt - 02-04-2020, 01:43 PM
RE: wasp-os: MicroPython for PineTime! - by mulm - 02-22-2020, 09:31 AM
RE: wasp-os: MicroPython for PineTime! - by mulm - 02-22-2020, 10:45 AM
RE: wasp-os: MicroPython for PineTime! - by 33YN2 - 03-06-2020, 04:02 PM
RE: wasp-os: MicroPython for PineTime! - by 33YN2 - 04-13-2020, 09:46 PM
RE: wasp-os: MicroPython for PineTime! - by tllim - 04-20-2020, 11:47 AM
RE: wasp-os: MicroPython for PineTime! - by danielt - 06-03-2020, 02:55 AM
wasp-os: MicroPython for PineTime! - by lupyuen - 05-28-2020, 01:59 AM
RE: wasp-os: MicroPython for PineTime! - by 33YN2 - 07-15-2020, 07:01 PM
wasp-os: MicroPython for PineTime! - by lupyuen - 06-03-2020, 05:38 PM
wasp-os: MicroPython for PineTime! - by lupyuen - 07-15-2020, 07:08 PM
wasp-os: MicroPython for PineTime! - by lupyuen - 07-16-2020, 02:43 AM
wasp-os: MicroPython for PineTime! - by lupyuen - 07-16-2020, 03:53 AM
wasp-os: MicroPython for PineTime! - by lupyuen - 08-02-2020, 03:55 AM
RE: wasp-os: MicroPython for PineTime! - by Igor7 - 10-11-2020, 07:27 AM
RE: wasp-os: MicroPython for PineTime! - by 33YN2 - 10-15-2020, 06:39 PM
RE: wasp-os: MicroPython for PineTime! - by 33YN2 - 10-24-2020, 01:56 PM
  Develop a new firmware for PineTime belushi 2 1,448 09-25-2023, 12:32 PM
Last Post: ccchan234
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 599 08-20-2023, 05:17 AM
Last Post: Luno
  Zephyr Backlight Examples for PineTime lcj 0 780 05-06-2023, 02:54 PM
Last Post: lcj
  Zephyr is ready for pinetime jandy 1 2,217 05-06-2023, 02:15 PM
Last Post: lcj
  Send a message from Android to pinetime via BLE razrosman 0 980 11-05-2022, 08:24 AM
Last Post: razrosman
  PineTime Stuck in DFU Mode Eesha Barua 1 2,203 07-25-2022, 09:17 PM
Last Post: heyhewmike
  Idle tracking with PineTime: how versatile it is? schaman 1 1,745 07-13-2022, 12:50 AM
Last Post: wibble
  PineTime implemented with partial of pebble API jandy 0 1,622 03-20-2022, 08:58 PM
Last Post: jandy
  "Pine64 USB JTAG Adapter + OpenOCD + PineTime" should it work? ITCactus 4 4,139 03-02-2022, 05:58 AM
Last Post: wibble
  Zephyr based Pinetime jandy 4 4,875 11-11-2021, 05:53 AM
Last Post: jandy
