PineTime Stuck in DFU Mode
Hello all,
I've so far successfully flashed Wasp-OS OTA to my PineTime from Infinitime using nRF Connect, and this time I wanted to go back and try the latest version of Infinitime.
After following this tutorial from the wiki and attempting to flash the reloader zip reloader-infinitime-recovery-0.14.1.zip, I have been stuck in DFU mode. nRF Connect freezes at 100%, and the log received an error for GATT connection timeout. I researched online and my issue seems consistent with what this tutorial warned ("Don't do this [update reloader zip] before updating the bootloader, otherwise your PineTime will freeze at the end of the process, and you will need to wait for the battery to go flat")
For now, my device is stuck in factory reset mode with the pinecone, start message and arrow. Is my problem that I uploaded the reloader zip before updating the bootloader? How can I fix this?
Thanks for all your help!
I had a similar problem going to wasp-os being stuck on that same screen and I found your post. I also came across another, see below reference, but uninstall nrf connect that you may have from the play store. Install the apk from their github https://github.com/NordicSemiconductor/A...ag/v4.24.3 this one to be exact. I just successfully installed wasp-os after nearly giving up on my watch.
Reference: https://www.reddit.com/r/pinetime/commen...rdfu_mode/
  Develop a new firmware for PineTime belushi 2 1,379 09-25-2023, 12:32 PM
Last Post: ccchan234
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 559 08-20-2023, 05:17 AM
Last Post: Luno
  Zephyr Backlight Examples for PineTime lcj 0 745 05-06-2023, 02:54 PM
Last Post: lcj
  Zephyr is ready for pinetime jandy 1 2,157 05-06-2023, 02:15 PM
Last Post: lcj
  Send a message from Android to pinetime via BLE razrosman 0 954 11-05-2022, 08:24 AM
Last Post: razrosman
  Idle tracking with PineTime: how versatile it is? schaman 1 1,694 07-13-2022, 12:50 AM
Last Post: wibble
  PineTime implemented with partial of pebble API jandy 0 1,593 03-20-2022, 08:58 PM
Last Post: jandy
  "Pine64 USB JTAG Adapter + OpenOCD + PineTime" should it work? ITCactus 4 4,034 03-02-2022, 05:58 AM
Last Post: wibble
  Zephyr based Pinetime jandy 4 4,780 11-11-2021, 05:53 AM
Last Post: jandy
  Problems with pinetime watch face simulator Elements 0 1,950 08-18-2021, 03:05 PM
Last Post: Elements
