(04-29-2020, 12:02 PM)newton688 Wrote: Hi All,
I'm having problems with GPS. It shows my location as 50km away from where I am currently located.
It looks like location is hooked in via the ModemManager. When I follow the manual page for mmcli to get the location at the command-line I'm getting some weird results.
debian@pinephone:~$ sudo mmcli -m 0 --enable
successfully enabled the modem
debian@pinephone:~$ sudo mmcli -m 0 --location-status
 Location | capabilities: 3gpp-lac-ci, gps-raw, gps-nmea, agps-msa, agps-msb
          |      enabled: 3gpp-lac-ci
          |      signals: no
 GPS      | refresh rate: 30 seconds
debian@pinephone:~$ sudo mmcli -m 0 --location-enable-gps-raw
successfully setup location gathering
debian@pinephone:~$ sudo mmcli -m 0 --location-enable-gps-nmea
debian@pinephone:~$ sudo mmcli -m 0 --location-get
 3GPP |      operator code: 302
      |      operator name: 610
      | location area code: FFFE
      | tracking area code: 2D8A
      |            cell id: 01D11F47
 GPS  |               nmea: ??A?Ui??,,1aB???,X0aBE??5f4P
      |                     ??A:t(??,X0aB???,X0aB???*lXi
      |                     ??A2Ej_?,(1aR???NX0YDE??2?5P
      |                     ??A:4*??AXDaB???,X0aB???,X0aBEJ?2?(
Where's the code for the custom ModemManager? I could have a look and see if I can figure out what goes wrong in my case.
Thanks,
Chris
I have seen this several times when I first bring up Maps, I think it is showing location based on IP address of my WiFi at first, then a few minutes later when GPS has locked in a few satellites it shows my location pretty accurately.
GPS is not a super strong signal anyway, I have seen it lose lock, or fail to acquire, in well shielded locations like metal buildings or even in heavy forest with little view of the sky.
Note in your code above, line 7:   signals :   no
debian+phosh running on PinePhone - by a-wai - 02-04-2020, 01:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-06-2020, 05:22 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 07:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-09-2020, 04:09 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-09-2020, 12:40 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 04:16 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:35 PM
RE: debian+phosh running on PinePhone - by tyha - 02-08-2020, 09:51 PM
RE: debian+phosh running on PinePhone - by nikola - 02-09-2020, 01:58 AM
RE: debian+phosh running on PinePhone - by njha - 02-10-2020, 05:08 PM
RE: debian+phosh running on PinePhone - by bcnaz - 02-09-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-17-2020, 05:32 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-19-2020, 02:29 AM
RE: debian+phosh running on PinePhone - by j23 - 02-21-2020, 01:52 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-22-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by j23 - 02-24-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-23-2020, 11:46 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-24-2020, 09:44 AM
RE: debian+phosh running on PinePhone - by Luke - 02-24-2020, 06:40 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 03:02 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 02:22 PM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 02:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 09:05 AM
RE: debian+phosh running on PinePhone - by rico - 02-25-2020, 07:55 AM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 09:52 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 01:56 PM
RE: debian+phosh running on PinePhone - by nas - 02-26-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 02:44 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 12:25 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 01:23 PM
RE: debian+phosh running on PinePhone - by nas - 02-27-2020, 02:19 PM
debian+phosh running on PinePhone - by ivanB1975 - 02-28-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by murak - 02-28-2020, 05:27 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-28-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-29-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by nas - 02-29-2020, 12:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 04:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-01-2020, 12:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 12:46 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-01-2020, 02:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-01-2020, 07:28 PM
RE: debian+phosh running on PinePhone - by sundog - 03-01-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 01:14 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 04:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 10:44 AM
RE: debian+phosh running on PinePhone - by buffer - 03-02-2020, 10:12 PM
RE: debian+phosh running on PinePhone - by rico - 03-03-2020, 08:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-03-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 07:16 PM
RE: debian+phosh running on PinePhone - by buffer - 03-03-2020, 06:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 03:28 AM
RE: debian+phosh running on PinePhone - by nas - 03-04-2020, 10:11 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 05:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-09-2020, 01:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 08:10 AM
RE: debian+phosh running on PinePhone - by rico - 03-04-2020, 10:06 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-05-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by buffer - 03-08-2020, 11:02 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 02:39 AM
RE: debian+phosh running on PinePhone - by saba - 03-09-2020, 04:43 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 08:16 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-09-2020, 11:57 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 02:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-09-2020, 09:54 AM
RE: debian+phosh running on PinePhone - by Quaa - 03-09-2020, 02:02 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 02:57 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 04:01 AM
RE: debian+phosh running on PinePhone - by clover - 03-10-2020, 12:39 PM
RE: debian+phosh running on PinePhone - by murak - 03-10-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 08:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:19 AM
RE: debian+phosh running on PinePhone - by clover - 03-11-2020, 01:22 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:39 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:58 PM
RE: debian+phosh running on PinePhone - by rubenr - 03-11-2020, 07:51 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-12-2020, 03:43 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 05:02 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 07:58 AM
RE: debian+phosh running on PinePhone - by saba - 03-12-2020, 08:47 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 03:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 07:34 PM
RE: debian+phosh running on PinePhone - by rico - 03-12-2020, 05:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 06:04 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 01:19 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 04:55 AM
RE: debian+phosh running on PinePhone - by murak - 03-13-2020, 04:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 07:44 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 07:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 09:26 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 09:57 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 01:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-14-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 08:01 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-15-2020, 01:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-15-2020, 06:11 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 08:47 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-15-2020, 09:27 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-15-2020, 09:28 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 11:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 03:25 AM
RE: debian+phosh running on PinePhone - by rmgr - 03-17-2020, 01:04 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by rico - 03-16-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 11:26 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-16-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 06:02 PM
RE: debian+phosh running on PinePhone - by rico - 03-17-2020, 12:16 PM
RE: debian+phosh running on PinePhone - by Luke - 03-17-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-17-2020, 04:30 PM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 12:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-18-2020, 03:29 AM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 03:10 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-18-2020, 05:29 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 03:07 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:40 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-18-2020, 09:14 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 03:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 05:25 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 07:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 12:35 PM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 07:42 AM
RE: debian+phosh running on PinePhone - by buffer - 03-19-2020, 11:13 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 08:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 03:57 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 04:52 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 05:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 06:33 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-21-2020, 08:54 AM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:30 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-21-2020, 05:46 PM
RE: debian+phosh running on PinePhone - by rico - 03-22-2020, 12:29 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 09:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 07:45 PM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 05:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:08 AM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-23-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 05:59 PM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 06:42 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 07:26 PM
RE: debian+phosh running on PinePhone - by buffer - 03-27-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-28-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 08:25 AM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 11:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by rico - 03-24-2020, 01:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:38 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 04:17 PM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 06:26 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-25-2020, 07:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-26-2020, 09:36 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-26-2020, 10:10 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-27-2020, 04:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-27-2020, 11:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-27-2020, 03:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 10:52 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 08:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 11:40 PM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 05:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 08:34 AM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 10:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 11:34 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 03:05 PM
RE: debian+phosh running on PinePhone - by nas - 03-29-2020, 12:38 PM
RE: debian+phosh running on PinePhone - by murak - 03-29-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 10:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 12:35 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-30-2020, 03:10 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:29 AM
RE: debian+phosh running on PinePhone - by Luke - 03-30-2020, 05:33 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 07:04 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 07:07 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 10:42 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 04:04 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 06:01 PM
RE: debian+phosh running on PinePhone - by rico - 03-30-2020, 11:03 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 05:21 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-31-2020, 07:09 AM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 08:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 03:59 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by buffer - 03-31-2020, 09:08 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 09:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-01-2020, 09:35 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:05 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 08:51 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 09:32 AM
RE: debian+phosh running on PinePhone - by janw - 04-01-2020, 02:18 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 11:55 PM
RE: debian+phosh running on PinePhone - by janw - 04-03-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-04-2020, 02:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-05-2020, 04:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-05-2020, 12:03 PM
RE: debian+phosh running on PinePhone - by clover - 04-06-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-06-2020, 12:12 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 06:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:22 AM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 12:45 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 08:22 PM
RE: debian+phosh running on PinePhone - by janw - 04-07-2020, 01:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 03:36 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 03:38 PM
RE: debian+phosh running on PinePhone - by johns - 04-08-2020, 06:56 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:10 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:08 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:54 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 03:41 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:28 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 05:00 PM
RE: debian+phosh running on PinePhone - by rico - 04-09-2020, 02:00 AM
RE: debian+phosh running on PinePhone - by nas - 04-10-2020, 04:03 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 04:32 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by rico - 04-12-2020, 12:32 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 12:10 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by rico - 04-13-2020, 08:15 AM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 09:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 10:15 AM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 02:07 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 03:24 PM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 11:58 PM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 08:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 12:49 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 10:05 AM
RE: debian+phosh running on PinePhone - by Boern - 04-14-2020, 10:18 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 06:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by janw - 04-16-2020, 09:24 AM
RE: debian+phosh running on PinePhone - by wibble - 08-03-2020, 08:18 AM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 03:34 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 04-15-2020, 01:05 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 08:59 PM
RE: debian+phosh running on PinePhone - by nas - 04-16-2020, 06:46 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 09:15 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-17-2020, 08:55 PM
RE: debian+phosh running on PinePhone - by Boern - 04-18-2020, 10:33 AM
RE: debian+phosh running on PinePhone - by rico - 04-18-2020, 10:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 03:36 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 05:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 06:22 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-20-2020, 11:05 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 12:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 03:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-21-2020, 03:05 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 04:06 AM
RE: debian+phosh running on PinePhone - by wibble - 04-21-2020, 09:58 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 10:23 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 03:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 06:14 PM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 06:30 PM
RE: debian+phosh running on PinePhone - by devrtz - 04-22-2020, 03:18 PM
RE: debian+phosh running on PinePhone - by Boern - 04-22-2020, 04:10 AM
RE: debian+phosh running on PinePhone - by dodoeg - 04-22-2020, 06:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-23-2020, 05:21 AM
RE: debian+phosh running on PinePhone - by Boern - 04-24-2020, 08:20 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-24-2020, 12:58 PM
RE: debian+phosh running on PinePhone - by Boern - 04-25-2020, 04:53 AM
RE: debian+phosh running on PinePhone - by rico - 04-25-2020, 08:42 PM
RE: debian+phosh running on PinePhone - by Boern - 04-26-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-26-2020, 03:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-27-2020, 11:23 AM
RE: debian+phosh running on PinePhone - by Boern - 04-28-2020, 02:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-28-2020, 08:29 AM
RE: debian+phosh running on PinePhone - by rico - 04-28-2020, 12:01 PM
RE: debian+phosh running on PinePhone - by rico - 04-30-2020, 11:39 PM
RE: debian+phosh running on PinePhone - by rico - 05-02-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by ieure - 04-28-2020, 09:44 PM
RE: debian+phosh running on PinePhone - by wi_badger - 04-29-2020, 09:51 PM
RE: debian+phosh running on PinePhone - by Boern - 04-30-2020, 03:35 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 06:21 AM
RE: debian+phosh running on PinePhone - by Boern - 05-01-2020, 06:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 09:07 AM
RE: debian+phosh running on PinePhone - by spaetz - 05-03-2020, 01:30 PM
Pass code / login screen - by Juergen - 05-04-2020, 10:59 PM
RE: Pass code / login screen - by dukla2000 - 05-05-2020, 01:13 AM
RE: Pass code / login screen - by dflag84 - 05-06-2020, 10:47 AM
RE: Pass code / login screen - by chris_02 - 05-06-2020, 02:14 PM
RE: Pass code / login screen - by dukla2000 - 05-31-2020, 05:35 AM
RE: debian+phosh running on PinePhone - by nas - 05-04-2020, 09:52 PM
RE: debian+phosh running on PinePhone - by Luke - 05-04-2020, 09:18 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-05-2020, 04:59 AM
RE: debian+phosh running on PinePhone - by nas - 05-06-2020, 04:53 AM
Convergence - by heng - 05-07-2020, 05:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-08-2020, 01:01 AM
RE: debian+phosh running on PinePhone - by Boern - 05-08-2020, 03:45 AM
shutdown - by Juergen - 05-09-2020, 01:51 AM
RE: shutdown - by dukla2000 - 05-09-2020, 03:18 AM
RE: shutdown - by Juergen - 05-19-2020, 10:52 PM
RE: shutdown - by Juergen - 06-14-2020, 10:58 PM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 05:23 AM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 11:39 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 02:11 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-14-2020, 09:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-05-2020, 04:59 PM
debian+phosh running on PinePhone - by ivanB1975 - 06-15-2020, 03:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-15-2020, 11:55 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-16-2020, 09:29 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 01:49 PM
RE: debian+phosh running on PinePhone - by klick - 08-03-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by Kamzzy - 07-09-2020, 07:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 07-09-2020, 08:37 AM
RE: debian+phosh running on PinePhone - by a-wai - 08-03-2020, 05:02 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-03-2020, 05:39 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 02:27 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:11 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 03:28 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:51 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-05-2020, 05:42 PM
RE: debian+phosh running on PinePhone - by Cree - 09-01-2020, 10:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-01-2020, 10:00 PM
RE: debian+phosh running on PinePhone - by klick - 09-02-2020, 04:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-02-2020, 04:33 PM
  atinout binaries for mobian/debian? NeutralGrey 2 83 Yesterday, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,755 05-09-2024, 03:08 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,755 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,552 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,735 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 3,116 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,372 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 169,206 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,392 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,290 03-01-2023, 04:45 PM
Users browsing this thread: 8 Guest(s)
