#90
(03-02-2020, 10:12 PM)buffer Wrote: @a-wai would you like to add details about your customized debian image in this wiki section? https://wiki.pine64.org/index.php/PinePh..._.2B_Phosh
Done, thanks for the suggestion!
(03-03-2020, 05:32 AM)harvey186 Wrote: Since the last both images the calendar app won't start on my PP. Does anyone has the same issue ?
(03-03-2020, 11:29 AM)parkerwb Wrote: Rats... can't get 2/29 to boot. Hits the splash screen and just reboots itself. Will try to track it down. On a slow ass 8GB card.
Everything works fine here, but I'll check once more tomorrow, in case I missed something.
(03-03-2020, 11:29 AM)parkerwb Wrote: Tried building image from scratch using ./build.sh and got:
Unfortunately that can happen: this system is based on Debian unstable, meaning dependencies break quite often (and at the moment, we need packages that haven't made their way into "testing" yet, so we can't avoid that).
(03-03-2020, 01:14 PM)nas Wrote: I eventually built phoc and wlroots but I get the attached error when running it. I guess randomly stumbling around can only get you so far!
You should build these the debian way, which is, from the package's source dir:
sudo apt build-dep .
dpkg-buildpackage -uc -us -b
So that you can install using dpkg. Afterwards, just reboot and you'll use your all new phoc. But I suggest you google these commands firstand read a bit about it, debian package building can be tricky on your first attempts Wink
(by the way, the UI is running inside phoc, so to speak, which means you can't just launch phoc from the terminal app, as there is already an instance of phoc running, installing a new package and rebooting is the only way to test)
debian+phosh running on PinePhone - by a-wai - 02-04-2020, 01:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-06-2020, 05:22 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 07:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-09-2020, 04:09 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-09-2020, 12:40 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by Leiaz - 02-08-2020, 04:16 PM
RE: debian+phosh running on PinePhone - by rico - 02-08-2020, 08:35 PM
RE: debian+phosh running on PinePhone - by tyha - 02-08-2020, 09:51 PM
RE: debian+phosh running on PinePhone - by nikola - 02-09-2020, 01:58 AM
RE: debian+phosh running on PinePhone - by njha - 02-10-2020, 05:08 PM
RE: debian+phosh running on PinePhone - by bcnaz - 02-09-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-17-2020, 05:32 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-19-2020, 02:29 AM
RE: debian+phosh running on PinePhone - by j23 - 02-21-2020, 01:52 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-22-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by j23 - 02-24-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-23-2020, 11:46 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-24-2020, 09:44 AM
RE: debian+phosh running on PinePhone - by Luke - 02-24-2020, 06:40 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 03:02 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-25-2020, 02:22 PM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 02:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 09:05 AM
RE: debian+phosh running on PinePhone - by rico - 02-25-2020, 07:55 AM
RE: debian+phosh running on PinePhone - by rico - 02-26-2020, 09:52 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 01:56 PM
RE: debian+phosh running on PinePhone - by nas - 02-26-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-26-2020, 02:44 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 12:25 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-27-2020, 01:23 PM
RE: debian+phosh running on PinePhone - by nas - 02-27-2020, 02:19 PM
debian+phosh running on PinePhone - by ivanB1975 - 02-28-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by murak - 02-28-2020, 05:27 AM
RE: debian+phosh running on PinePhone - by a-wai - 02-28-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 02-29-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by nas - 02-29-2020, 12:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 04:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-01-2020, 12:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-01-2020, 12:46 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-01-2020, 02:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-01-2020, 07:28 PM
RE: debian+phosh running on PinePhone - by sundog - 03-01-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 01:14 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 04:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-02-2020, 10:44 AM
RE: debian+phosh running on PinePhone - by buffer - 03-02-2020, 10:12 PM
RE: debian+phosh running on PinePhone - by rico - 03-03-2020, 08:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-03-2020, 05:17 PM
RE: debian+phosh running on PinePhone - by nas - 03-03-2020, 07:16 PM
RE: debian+phosh running on PinePhone - by buffer - 03-03-2020, 06:56 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 03:28 AM
RE: debian+phosh running on PinePhone - by nas - 03-04-2020, 10:11 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 05:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-09-2020, 01:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-04-2020, 08:10 AM
RE: debian+phosh running on PinePhone - by rico - 03-04-2020, 10:06 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-05-2020, 08:27 AM
RE: debian+phosh running on PinePhone - by buffer - 03-08-2020, 11:02 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 02:39 AM
RE: debian+phosh running on PinePhone - by saba - 03-09-2020, 04:43 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-09-2020, 08:16 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-09-2020, 11:57 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 02:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-09-2020, 09:54 AM
RE: debian+phosh running on PinePhone - by Quaa - 03-09-2020, 02:02 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 02:57 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-10-2020, 04:01 AM
RE: debian+phosh running on PinePhone - by clover - 03-10-2020, 12:39 PM
RE: debian+phosh running on PinePhone - by murak - 03-10-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-10-2020, 08:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:19 AM
RE: debian+phosh running on PinePhone - by clover - 03-11-2020, 01:22 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:39 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-11-2020, 03:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-11-2020, 03:58 PM
RE: debian+phosh running on PinePhone - by rubenr - 03-11-2020, 07:51 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-12-2020, 03:43 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 05:02 AM
RE: debian+phosh running on PinePhone - by murak - 03-12-2020, 07:58 AM
RE: debian+phosh running on PinePhone - by saba - 03-12-2020, 08:47 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 03:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 07:34 PM
RE: debian+phosh running on PinePhone - by rico - 03-12-2020, 05:53 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-12-2020, 06:04 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 01:19 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 04:55 AM
RE: debian+phosh running on PinePhone - by murak - 03-13-2020, 04:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 05:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 07:44 PM
RE: debian+phosh running on PinePhone - by rico - 03-13-2020, 07:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-13-2020, 09:26 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-13-2020, 09:57 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 01:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-14-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by rico - 03-14-2020, 08:01 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-15-2020, 01:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-15-2020, 06:11 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 08:47 PM
RE: debian+phosh running on PinePhone - by rmgr - 03-15-2020, 09:27 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-15-2020, 09:28 PM
RE: debian+phosh running on PinePhone - by rico - 03-15-2020, 11:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 03:25 AM
RE: debian+phosh running on PinePhone - by rmgr - 03-17-2020, 01:04 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by rico - 03-16-2020, 11:19 AM
RE: debian+phosh running on PinePhone - by Luke - 03-16-2020, 11:26 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-16-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-16-2020, 06:02 PM
RE: debian+phosh running on PinePhone - by rico - 03-17-2020, 12:16 PM
RE: debian+phosh running on PinePhone - by Luke - 03-17-2020, 01:24 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-17-2020, 04:30 PM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 12:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-18-2020, 03:29 AM
RE: debian+phosh running on PinePhone - by buffer - 03-18-2020, 03:10 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-18-2020, 05:29 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 03:07 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:40 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-19-2020, 03:25 PM
RE: debian+phosh running on PinePhone - by nas - 03-18-2020, 09:14 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 03:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 05:25 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 07:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-19-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 12:35 PM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by rico - 03-19-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by vinnie - 03-19-2020, 07:42 AM
RE: debian+phosh running on PinePhone - by buffer - 03-19-2020, 11:13 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 08:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 03:57 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 04:52 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 05:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:02 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-20-2020, 06:33 PM
RE: debian+phosh running on PinePhone - by rico - 03-20-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-21-2020, 08:54 AM
RE: debian+phosh running on PinePhone - by buffer - 03-21-2020, 02:30 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-21-2020, 05:46 PM
RE: debian+phosh running on PinePhone - by rico - 03-22-2020, 12:29 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-22-2020, 09:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-22-2020, 07:45 PM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 05:14 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:08 AM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-23-2020, 04:58 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 05:59 PM
RE: debian+phosh running on PinePhone - by Luke - 03-23-2020, 06:42 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-23-2020, 07:26 PM
RE: debian+phosh running on PinePhone - by buffer - 03-27-2020, 05:56 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-28-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by rico - 03-23-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 08:25 AM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 11:08 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by rico - 03-24-2020, 01:04 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-24-2020, 01:38 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-24-2020, 04:17 PM
RE: debian+phosh running on PinePhone - by Luke - 03-24-2020, 06:26 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-25-2020, 07:21 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-26-2020, 09:36 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-26-2020, 10:10 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-27-2020, 04:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-27-2020, 11:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-27-2020, 03:44 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 10:52 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 08:27 PM
RE: debian+phosh running on PinePhone - by buffer - 03-28-2020, 11:40 PM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 05:48 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 08:34 AM
RE: debian+phosh running on PinePhone - by janw - 03-29-2020, 10:54 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 11:34 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-29-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by fpb4 - 03-29-2020, 03:05 PM
RE: debian+phosh running on PinePhone - by nas - 03-29-2020, 12:38 PM
RE: debian+phosh running on PinePhone - by murak - 03-29-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-29-2020, 10:31 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 12:35 AM
RE: debian+phosh running on PinePhone - by RMJ250 - 03-30-2020, 03:10 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:29 AM
RE: debian+phosh running on PinePhone - by Luke - 03-30-2020, 05:33 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 05:40 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 07:04 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 07:07 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 10:42 AM
debian+phosh running on PinePhone - by ivanB1975 - 03-30-2020, 04:04 PM
RE: debian+phosh running on PinePhone - by a-wai - 03-30-2020, 06:01 PM
RE: debian+phosh running on PinePhone - by rico - 03-30-2020, 11:03 PM
RE: debian+phosh running on PinePhone - by bcnaz - 03-30-2020, 05:21 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 03:09 AM
RE: debian+phosh running on PinePhone - by a-wai - 03-31-2020, 07:09 AM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 08:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 03:59 AM
RE: debian+phosh running on PinePhone - by bcnaz - 03-31-2020, 01:43 PM
RE: debian+phosh running on PinePhone - by buffer - 03-31-2020, 09:08 PM
RE: debian+phosh running on PinePhone - by rico - 03-31-2020, 09:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-01-2020, 09:35 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:05 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-01-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 08:51 AM
RE: debian+phosh running on PinePhone - by Lanza - 04-01-2020, 09:32 AM
RE: debian+phosh running on PinePhone - by janw - 04-01-2020, 02:18 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 12:15 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-01-2020, 11:55 PM
RE: debian+phosh running on PinePhone - by janw - 04-03-2020, 09:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-04-2020, 02:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-05-2020, 04:57 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-05-2020, 12:03 PM
RE: debian+phosh running on PinePhone - by clover - 04-06-2020, 09:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-06-2020, 12:12 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 06:24 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:22 AM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 12:45 PM
RE: debian+phosh running on PinePhone - by buffer - 04-06-2020, 08:22 PM
RE: debian+phosh running on PinePhone - by janw - 04-07-2020, 01:50 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 03:36 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 03:38 PM
RE: debian+phosh running on PinePhone - by johns - 04-08-2020, 06:56 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-07-2020, 01:10 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:08 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 02:54 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 03:41 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:28 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 04:34 PM
RE: debian+phosh running on PinePhone - by buffer - 04-07-2020, 04:43 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-07-2020, 05:00 PM
RE: debian+phosh running on PinePhone - by rico - 04-09-2020, 02:00 AM
RE: debian+phosh running on PinePhone - by nas - 04-10-2020, 04:03 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 04:32 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-10-2020, 06:06 AM
RE: debian+phosh running on PinePhone - by rico - 04-12-2020, 12:32 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 12:10 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by rico - 04-13-2020, 08:15 AM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 09:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-13-2020, 10:15 AM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 02:07 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 03:24 PM
RE: debian+phosh running on PinePhone - by nas - 04-13-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by Luke - 04-13-2020, 04:47 PM
RE: debian+phosh running on PinePhone - by Boern - 04-13-2020, 11:58 PM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 08:30 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 12:49 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-14-2020, 10:05 AM
RE: debian+phosh running on PinePhone - by Boern - 04-14-2020, 10:18 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 06:41 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-16-2020, 08:19 AM
RE: debian+phosh running on PinePhone - by janw - 04-16-2020, 09:24 AM
RE: debian+phosh running on PinePhone - by wibble - 08-03-2020, 08:18 AM
RE: debian+phosh running on PinePhone - by nas - 04-14-2020, 03:34 PM
RE: debian+phosh running on PinePhone - by RMJ250 - 04-15-2020, 01:05 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-15-2020, 08:59 PM
RE: debian+phosh running on PinePhone - by nas - 04-16-2020, 06:46 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 09:15 AM
RE: debian+phosh running on PinePhone - by rico - 04-16-2020, 10:04 AM
RE: debian+phosh running on PinePhone - by bcnaz - 04-17-2020, 08:55 PM
RE: debian+phosh running on PinePhone - by Boern - 04-18-2020, 10:33 AM
RE: debian+phosh running on PinePhone - by rico - 04-18-2020, 10:41 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 03:36 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 05:19 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-19-2020, 06:22 AM
RE: debian+phosh running on PinePhone - by wibble - 04-19-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-20-2020, 11:05 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 12:51 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 01:53 AM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 03:50 PM
RE: debian+phosh running on PinePhone - by bcnaz - 04-21-2020, 03:05 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 04:06 AM
RE: debian+phosh running on PinePhone - by wibble - 04-21-2020, 09:58 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 10:23 AM
RE: debian+phosh running on PinePhone - by Luke - 04-21-2020, 03:20 PM
RE: debian+phosh running on PinePhone - by a-wai - 04-21-2020, 06:14 PM
RE: debian+phosh running on PinePhone - by pjsf - 04-21-2020, 06:30 PM
RE: debian+phosh running on PinePhone - by devrtz - 04-22-2020, 03:18 PM
RE: debian+phosh running on PinePhone - by Boern - 04-22-2020, 04:10 AM
RE: debian+phosh running on PinePhone - by dodoeg - 04-22-2020, 06:12 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-23-2020, 05:21 AM
RE: debian+phosh running on PinePhone - by Boern - 04-24-2020, 08:20 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-24-2020, 12:58 PM
RE: debian+phosh running on PinePhone - by Boern - 04-25-2020, 04:53 AM
RE: debian+phosh running on PinePhone - by rico - 04-25-2020, 08:42 PM
RE: debian+phosh running on PinePhone - by Boern - 04-26-2020, 02:49 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-26-2020, 03:16 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-27-2020, 11:23 AM
RE: debian+phosh running on PinePhone - by Boern - 04-28-2020, 02:04 AM
RE: debian+phosh running on PinePhone - by a-wai - 04-28-2020, 08:29 AM
RE: debian+phosh running on PinePhone - by rico - 04-28-2020, 12:01 PM
RE: debian+phosh running on PinePhone - by rico - 04-30-2020, 11:39 PM
RE: debian+phosh running on PinePhone - by rico - 05-02-2020, 07:33 PM
RE: debian+phosh running on PinePhone - by ieure - 04-28-2020, 09:44 PM
RE: debian+phosh running on PinePhone - by Boern - 04-30-2020, 03:35 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 05:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 06:21 AM
RE: debian+phosh running on PinePhone - by Boern - 05-01-2020, 06:41 AM
RE: debian+phosh running on PinePhone - by Luke - 05-01-2020, 09:07 AM
RE: debian+phosh running on PinePhone - by spaetz - 05-03-2020, 01:30 PM
Pass code / login screen - by Juergen - 05-04-2020, 10:59 PM
RE: Pass code / login screen - by dukla2000 - 05-05-2020, 01:13 AM
RE: Pass code / login screen - by dflag84 - 05-06-2020, 10:47 AM
RE: Pass code / login screen - by chris_02 - 05-06-2020, 02:14 PM
RE: Pass code / login screen - by dukla2000 - 05-31-2020, 05:35 AM
RE: debian+phosh running on PinePhone - by nas - 05-04-2020, 09:52 PM
RE: debian+phosh running on PinePhone - by Luke - 05-04-2020, 09:18 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-05-2020, 04:59 AM
RE: debian+phosh running on PinePhone - by nas - 05-06-2020, 04:53 AM
Convergence - by heng - 05-07-2020, 05:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 05-08-2020, 01:01 AM
RE: debian+phosh running on PinePhone - by Boern - 05-08-2020, 03:45 AM
shutdown - by Juergen - 05-09-2020, 01:51 AM
RE: shutdown - by dukla2000 - 05-09-2020, 03:18 AM
RE: shutdown - by Juergen - 05-19-2020, 10:52 PM
RE: shutdown - by Juergen - 06-14-2020, 10:58 PM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 02:13 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 05:23 AM
RE: debian+phosh running on PinePhone - by rico - 05-09-2020, 11:39 AM
RE: debian+phosh running on PinePhone - by heng - 05-09-2020, 02:11 PM
RE: debian+phosh running on PinePhone - by a-wai - 05-14-2020, 09:47 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-05-2020, 04:59 PM
debian+phosh running on PinePhone - by ivanB1975 - 06-15-2020, 03:44 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-15-2020, 11:55 AM
RE: debian+phosh running on PinePhone - by a-wai - 06-16-2020, 09:29 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 06:42 AM
RE: debian+phosh running on PinePhone - by jjs - 07-05-2020, 01:49 PM
RE: debian+phosh running on PinePhone - by klick - 08-03-2020, 11:25 AM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 07:38 AM
RE: debian+phosh running on PinePhone - by Kamzzy - 07-09-2020, 07:53 AM
RE: debian+phosh running on PinePhone - by a-wai - 07-09-2020, 08:37 AM
RE: debian+phosh running on PinePhone - by a-wai - 08-03-2020, 05:02 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-03-2020, 05:39 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 02:27 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:11 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 03:28 PM
RE: debian+phosh running on PinePhone - by klick - 08-04-2020, 03:51 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-04-2020, 04:13 PM
RE: debian+phosh running on PinePhone - by bcnaz - 08-05-2020, 05:42 PM
RE: debian+phosh running on PinePhone - by Cree - 09-01-2020, 10:07 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-01-2020, 10:00 PM
RE: debian+phosh running on PinePhone - by klick - 09-02-2020, 04:09 PM
RE: debian+phosh running on PinePhone - by bcnaz - 09-02-2020, 04:33 PM
  atinout binaries for mobian/debian? NeutralGrey 2 103 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,787 05-09-2024, 03:08 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,759 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,556 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,748 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 3,128 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,377 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 169,554 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,394 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
Users browsing this thread: 8 Guest(s)
