Boot from SD and edit screen res on native OS?
(01-26-2020, 05:37 PM)xmixahlx Wrote: you don't want to change the resolution. keep this at FHD. you can use scaling if supported by the window manager.
Very good... Thanks for the tip!  Is my process, listed above, correct to get the resolution set back tondrlefault?  As, right now .. booting from the default OS, I just have a black screen. :-( I would need to know what file to make the change in, however. I can probably being around until I find it. I've done a reasonable amount of work on Linux, but pretty much only on working systems. :-)
Dennis Hoshield
PBPro/ANSI/Manjaro
RE: Boot from SD and edit screen res on native OS? - by dhosh - 01-26-2020, 05:47 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 344 02-23-2024, 04:22 PM
Last Post: tuxxpine
  uboot wont boot to SD card after upgrade jbradley419 7 994 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 332 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,393 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 781 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 647 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,276 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,998 08-03-2023, 03:30 PM
  Black screen by start up bluedemon382 10 3,151 07-27-2023, 07:49 AM
Last Post: dstallmo
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 830 07-13-2023, 01:50 PM
Last Post: PaulQ
