Pinebook Pro Revised Keyboard Firmware
#36
(02-05-2020, 01:18 AM)ssfrfr@ Wrote:
(02-04-2020, 07:53 AM)jackhumbert Wrote:
(02-04-2020, 07:07 AM)Arwen Wrote: @jackhumbert I think @ssfrfr@ was looking to add the Dvorak on ANSI PBP mapping to your respository, for others to use. Then a user simply selects the key mapping they want. (I want the control key in the correct place, Unix style :-).
Yeah! I went ahead and added that keymap along with the hex Smile
Thank you!
And thanks for the explanation of the proper way to do it.
My enter key double-taps rather frequently -- is it possible to adjust the debounce filtering?  The current firmware does it less often.
Has anything been done with the touchpad?
It went from "tap to click works, but it loves to put my terminals in read-only mode while I'm typing" to "click-to-click, but much better palm rejection" and I don't know if it's a firmware or OS change yet.
I haven't looked into the debouncing stuff much yet, but it might be possible to adjust something there - I didn't mess with that in the updated firmware Smile
I don't think much customisation of the trackpad is possible from the firmware at this point, but I and others have had luck with modifying some of the settings in the OS for that: https://wiki.pine64.org/index.php/Pinebo...pad_tuning
RE: Pinebook Pro Revised Keyboard Firmware - by jackhumbert - 02-05-2020, 10:02 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 702 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 372 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 318 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 658 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,163 11-07-2023, 10:09 AM
Last Post: DrYak
  Separate ISO keyboard for PBP Besouro 0 733 06-04-2023, 02:51 PM
Last Post: Besouro
  PineBook Pro dead ottahe 9 6,115 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,543 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,902 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,958 10-21-2022, 07:57 AM
Last Post: dachalife
