Sound Quit
(01-14-2020, 01:02 PM)tophneal Wrote: I haven't used the default Debian much, so the ways I can help are limited. I recall when I first got mine (though I can't recall if I switched to Manjaro by this time) has sound issues, and I had to select a different output device.
Have you also checked out this section of the wiki, yet? https://wiki.pine64.org/index.php/Pinebo...und_issues It doesn't have any solid answers to your problem, but it has some good first steps. For example, have you tried testing sound while booted from an image on an SD? That should help identify if it's hardware or software.
Thanks for your effort to help me.  But as luck would have it, I rebooted several times and then the sound returned.  I will take your recommendation on the SD card in order to have a backup in case it is software related.  I really do appreciate your responding, especially since I have only been using it for a few hours.  It helps to know that there is somewhere to turn.  Thank you.
Sound Quit - by TonyK - 01-14-2020, 10:51 AM
RE: Sound Quit - by tophneal - 01-14-2020, 12:05 PM
RE: Sound Quit - by TonyK - 01-14-2020, 12:30 PM
RE: Sound Quit - by tophneal - 01-14-2020, 01:02 PM
RE: Sound Quit - by TonyK - 01-14-2020, 01:21 PM
RE: Sound Quit - by tophneal - 01-14-2020, 01:26 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 821 07-13-2023, 01:50 PM
Last Post: PaulQ
  alarming sound coming from pinebook pro jazzhands 2 1,667 08-21-2022, 02:34 PM
Last Post: foobar
  If booted with headphones in, sound comes from them and speakers stozi 6 5,622 06-11-2021, 01:27 AM
Last Post: dsimic
  No Sound on Default Manjaro KDE carlosqueso 4 5,208 04-01-2021, 07:17 AM
Last Post: carlosqueso
  Click or tick sound from right speaker Timpanogos Slim 0 2,110 06-04-2020, 07:33 PM
Last Post: Timpanogos Slim
  no sound from firefox Uturn 2 3,742 03-24-2020, 03:49 AM
Last Post: Uturn
  Sound driver 32bit sample format not working, some freezes and crashes through ALSA aeGh7fae 0 2,317 01-28-2020, 10:16 AM
Last Post: aeGh7fae
Sad New Pinebook Pro - no sound vve1505 9 13,130 01-17-2020, 10:11 AM
Last Post: chip ling
  No Sound, Non Root User deebeez 10 13,153 01-16-2020, 04:04 AM
Last Post: bcnaz
  No sound.... User 6582 9 11,621 12-19-2019, 10:10 PM
Last Post: User 6582
