Screen adjustment
(05-03-2020, 09:52 AM)buzzra Wrote:
(01-15-2020, 10:27 AM)tophneal Wrote: You could try using MATE Tweaks to change the HiDPI scaling. That should help with resizing several aspects of the DE and not just fonts.
No setting for HiDPI in default Mate Tweaks.
I've had my PBP since February, but rarely turn it on because of this problem. I can't even see it good enough to replace the default install. At least the purchase supported Pine64.
buzz
(I don't run MATE so I'm not sure here, but) if MATE Tweak doesn't have the HiDPI scaling option like in the image below
[Image: enable-hidpi.png]
You can try using this line in terminal, and just change the 1 to your desired scaling factor.
gsettings set org.mate.interface window-scaling-factor 1
Screen adjustment - by michael82 - 01-04-2020, 01:16 PM
RE: Screen adjustment - by inkslinger - 01-14-2020, 04:51 PM
RE: Screen adjustment - by RotatingNut - 01-15-2020, 05:02 AM
RE: Screen adjustment - by inkslinger - 01-15-2020, 10:24 AM
RE: Screen adjustment - by tophneal - 01-15-2020, 10:27 AM
RE: Screen adjustment - by buzzra - 05-03-2020, 09:52 AM
RE: Screen adjustment - by tophneal - 05-04-2020, 07:24 AM
RE: Screen adjustment - by ab1jx - 09-27-2020, 08:01 AM
RE: Screen adjustment - by moonwalkers - 09-28-2020, 09:00 AM
RE: Screen adjustment - by ab1jx - 09-28-2020, 05:00 PM
RE: Screen adjustment - by moonwalkers - 09-29-2020, 09:25 PM
RE: Screen adjustment - by Der Geist der Maschine - 10-01-2020, 08:37 PM
RE: Screen adjustment - by wdt - 09-28-2020, 05:49 PM
RE: Screen adjustment - by ab1jx - 10-14-2020, 05:00 PM
RE: Screen adjustment - by moonwalkers - 10-17-2020, 07:10 PM
RE: Screen adjustment - by ab1jx - 10-20-2020, 11:09 AM
RE: Screen adjustment - by moonwalkers - 10-21-2020, 09:22 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 309 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 3,019 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,034 04-01-2023, 07:55 AM
Last Post: hacknix
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,011 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,110 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,762 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,763 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 38,842 04-27-2021, 02:57 AM
Last Post: james64
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,708 01-27-2021, 10:48 PM
Last Post: rimaille
  Screen flicker with USB-C charging bchenlee609 5 5,896 01-25-2021, 08:48 PM
Last Post: bchenlee609
