Looking to commission a new Chromium build (COMMUNITY BOUNTY)
#41
Not really, I don't expect too much to be changed actually. I will try to get crostini working on the image install itself, given the things we discussed above. Widevine doesn't work (yet), of that I'm quite sure.
Okay, so this command
Quote:sudo crosvm run \
--cpus 6 \
--mem 3000 \
--socket /run/crosvm.sock \
-r /run/imageloader/cros-termina/12371.22.0/vm_rootfs.img \
/run/imageloader/cros-termina/12371.22.0/vm_kernel
fails, but it doesn't when we use mem 2000. The socket gives a problem though, I'm stuck at 'failed to notify host system that VM is ready'
(01-04-2020, 05:29 AM)obyknovenius Wrote: From source code of chromium I figured out the command that actually runs to start VM behind the GUI when you install Linux (Beta):
sudo crosvm run \
--cpus 6 \
--mem 3000 \
Where mem is the maximum memory vm allowed to use and the value is about 2/3 of all memory the memory. From journalctl output I  found that vm cannot be started with the error: cannot allocate memory errno 12.. If you remove this mem option it actually starts!
I tried to enable compact memory flag like here: https://stackoverflow.com/questions/4646...-available. I also tried to play with other kernel flags (don't remember already).
Can you use Mac to build chromium? Or you did install Ubuntu on it?
Can I ask you where you found this? It would be very helpful Smile
RE: Looking to commission a new Chromium build (COMMUNITY BOUNTY) - by brent.thierens - 02-04-2020, 02:20 PM
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,537 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Chromium OS 78? obyknovenius 2 6,057 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,731 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 3,867 11-04-2019, 08:38 AM
