Looking to commission a new Chromium build (COMMUNITY BOUNTY)
#29
Not built with mainline uboot yet, the image was built using MrFixit uboot. But it is something I plan to change in the future, just wanted to try other stuff first since the main issue, SD not being bootable anymore, was solved.
I will post any progress I make and check the link later Smile
RE: Looking to commission a new Chromium build (COMMUNITY BOUNTY) - by brent.thierens - 01-26-2020, 10:02 AM
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,577 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Chromium OS 78? obyknovenius 2 6,097 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,785 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 3,898 11-04-2019, 08:38 AM
