Looking to commission a new Chromium build (COMMUNITY BOUNTY)
#27
It would surprise me if Linux tools would work, since normally nothing has been changed. I'm trying right now to get an updated Linux kernel with more flags (the mrfixit kernel) under CrOS. Hopefully that solves something for this.
When I enable Linux, I get an error on the stage 'creating disk image'. Any chance you can find the error causing this? Maybe, there is just a package missing to create the vm image or so. Other errors after that might be a result from that. Can the tools be enabled from terminal so we have some log output?
RE: Looking to commission a new Chromium build (COMMUNITY BOUNTY) - by brent.thierens - 01-26-2020, 03:55 AM
  Black screen on both FydeOS as Chromium from github QuinTeknoLife 0 3,577 04-15-2021, 11:44 AM
Last Post: QuinTeknoLife
  Chromium OS 78? obyknovenius 2 6,094 02-04-2020, 02:11 PM
Last Post: brent.thierens
Question Does the Pinebook Pro support chromium developer mode? TDC_PBP 3 6,785 12-07-2019, 02:33 PM
Last Post: TDC_PBP
  Possible to use different uboot with Chromium? tophneal 1 3,897 11-04-2019, 08:38 AM
