ROCKPro64 pwm-fan inoperable
UPDATE:
Scope fixed. PWM is present at the base of Q2110 with peaks around 700mV. Disabled the CPU thermal zone to keep PWM consistent for further testing. D2101 is not present on this board and from the high res images on the website, this diode is also not present. Appears to be for reverse polarity protection.
When using the oscilliscope, I noticed that the fan starts spinning and responding to different PWM widths when the probes are touching pin 1 (+) of the fan connector and pin 3 (collector) of Q2110. Unfortunately, I saw R89554 briefly turn into an LED before releasing the magic. Likely due to exceeding maximum current rating by accidentally completing the circuit between VCC12V_DCIN through the resistor and then through Q2110 collector<->emitter to ground.
In conclusion - the fan driving circuit (R89554, R2, Q2110, D2101 (not present)) seems suboptimal, and possibly doesn't work with some fans? Mind you, this fan is the one purchased from pine store for use in the NAS case.
I can wire the fan directly to 12V but would prefer not to. Replacing the dead component(s) should be easy enough, but it's still a mystery why this circuit does not work.
See page 6:
http://files.pine64.org/doc/rockpro64/ro...21-SCH.pdf
RE: ROCKPro64 pwm-fan inoperable - by resistanceisfutile - 01-01-2020, 10:37 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,322 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 962 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,283 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 880 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,701 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,873 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,186 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,560 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,236 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,795 05-16-2022, 02:34 AM
Last Post: dukla2000
