Media Server for 4k monitor?
Fair warning, this laptop is not a true substitute for a chromebook. The OS options right now all have some limitations and quirks. Folks like MrFixIt do sterling work (much appreciated), but the scale of Raspeberry Pi's popularity means the OS and its software are very stable relative to Pinebook Pro (PBP).
That warning aside, if you or the recipient are comfortable with Linux, I don't see why you couldn't use the laptop as a media server. My feeling is you would be better served by one of the other pine products if that's your main use case; probably a single board computer of some kind.
For mixed usage, I think the PBP is great. I personally have used the LibreOffice install that comes with MrFixIt's default OS to do some quick work from home and it performed OK. I bought a generic combination USB-C hub with HDMI and USB-A and it works great for a second display. Given it's Linux, I was a little surprise when I plugged the hub and HDMI in and the second screen immediately worked. I'd put aside an hour for debugging.
Media Server for 4k monitor? - by jd38011 - 12-11-2019, 12:25 AM
RE: Media Server for 4k monitor? - by sinistermrcream - 12-11-2019, 08:22 AM
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,273 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  My pbp is a sleek, black, flat brick, and won't boot from any kind of media rotwang 15 14,122 08-24-2021, 04:25 PM
Last Post: bkenn
  External Monitor Recommendations SteveSquatch 1 1,844 02-17-2021, 08:23 AM
Last Post: Arwen
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,830 01-17-2021, 01:50 PM
Last Post: BananaPekan
  [split] Change password from external media James Good 11 13,074 07-23-2020, 02:42 PM
  USB-C to 4k monitor: right 1/3 not working robt 4 5,508 07-12-2020, 02:46 PM
Last Post: robt
  Pinebook Pro as an all-in-one boat server? nhm 8 8,510 05-17-2020, 08:43 PM
Last Post: xmixahlx
  Command line flashing script with media verification, xz image support Arglebargle 2 4,610 12-19-2019, 09:25 PM
Last Post: Arglebargle
