GPU accelaration ubuntu 18.04
(12-01-2019, 03:06 PM)Luke Wrote: Use MPV media player - that has accelerated video playack for files up-to 4K@30FPS.
You can also use SMplayer with 1080p files. For SMPlayer you just need to specify settings in the config.
Thanks, Luke!
smplayer works without lagging though it seems grainy.  I was using vlc.
Still can't get stellarium to work, though it worked right after I installed it.
Still works in the default debian build, but opens a small box and just sits there in Ubuntu/mate 18.04.
I was trying to get wine to work, when I started having video issues.  If I have to, I'll reflash the SD back to the original image and then reinstall stuff (carefully).
Thanks again!
de KL7JKC
RE: GPU accelaration ubuntu 18.04 - by tllim - 12-01-2019, 12:49 PM
RE: GPU accelaration ubuntu 18.04 - by Luke - 12-01-2019, 03:06 PM
RE: GPU accelaration ubuntu 18.04 - by Jeffersoniantoo - 12-01-2019, 03:18 PM
RE: GPU accelaration ubuntu 18.04 - by Luke - 12-01-2019, 05:12 PM
  After update in Ubuntu bionic mate system crashed Wawe 2 3,305 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu Installation on PBP narinderpal10 5 6,177 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 3,245 12-15-2020, 01:53 AM
Last Post: BryanF
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 19,864 11-19-2020, 03:16 AM
Last Post: FeMike
  Ubuntu 20.10 bastafari 6 7,499 10-27-2020, 10:16 AM
Last Post: Mangled
  How does one get working deep/S3 sleep with Ubuntu Focal/5.7 mainline kernel? Syonyk 7 10,145 10-26-2020, 02:03 PM
Last Post: edward
  Ubuntu 20.10 beta Mangled 21 21,686 10-12-2020, 07:13 AM
Last Post: Mangled
  ANSI keyboard fix for ubuntu Mangled 0 2,019 10-05-2020, 02:15 PM
Last Post: Mangled
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 37,075 09-06-2020, 08:20 AM
Last Post: pine76
  Ubuntu for RockPro64 dndeokar 1 3,607 08-14-2020, 06:42 AM
