Ubuntu 20.10
It's been released recently and with it an official image for raspberry pi 4 which is an arm device. Unfortunately I lack the knowledge to try and port/build myself but curious on opinions on how hard it would be to make a build for the pbp? Would this be useless at all https://launchpad.net/cubic
I'm sure the answer is no!
Sent from my OnePlus 7 Pro using Tapatalk
It is possible to upgrade from ayufan's Ubuntu 20.04.
(10-26-2020, 02:06 AM)Wizzard Wrote: It is possible to upgrade from ayufan's Ubuntu 20.04.
Hey,
The problem that we are having though is that sound don't work and keyboard mapping is scrambled. Is there a fix?
My sound works and the keyboard is OK.
(10-26-2020, 07:12 AM)Wizzard Wrote: My sound works and the keyboard is OK.
That is strange. I may have to try the install again. Are you using US keyboard setting? Also are you running armhf or arm64 version?
I am using Slovak layout, also have US layout installed and I can switch it. Ayufan's Ubuntu is ARM64.
edit: have you removed all the "ibus-*"packages?
(10-27-2020, 06:14 AM)Wizzard Wrote: I am using Slovak layout, also have US layout installed and I can switch it. Ayufan's Ubuntu is ARM64.
In my previous install, I have and that unfortunately did not fix it. I will try it again and this time boot from emmc.
  After update in Ubuntu bionic mate system crashed Wawe 2 7,359 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu Installation on PBP narinderpal10 5 12,305 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,743 12-15-2020, 01:53 AM
Last Post: BryanF
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 33,555 11-19-2020, 03:16 AM
Last Post: FeMike
  How does one get working deep/S3 sleep with Ubuntu Focal/5.7 mainline kernel? Syonyk 7 16,370 10-26-2020, 02:03 PM
Last Post: edward
  Ubuntu 20.10 beta Mangled 21 37,152 10-12-2020, 07:13 AM
Last Post: Mangled
  ANSI keyboard fix for ubuntu Mangled 0 3,394 10-05-2020, 02:15 PM
Last Post: Mangled
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 65,266 09-06-2020, 08:20 AM
Last Post: pine76
  Ubuntu for RockPro64 dndeokar 1 5,501 08-14-2020, 06:42 AM
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 45,712 07-02-2020, 11:04 AM
Last Post: mlentink
