Ubuntu 20.10 beta
Would it be possible to upgrade from the pinebook Ubuntu 20.04 image to 20.10 beta? Does anyone run Ubuntu currently? Does the Ubuntu os work fine on pinebook?
I think nobody yet tried that, but I will try for sure, don't know when, but maybe very soon. I just think that some things may stop working, like video acceleration, etc.
(10-05-2020, 03:52 AM)Wizzard Wrote: I think nobody yet tried that, but I will try for sure, don't know when, but maybe very soon. I just think that some things may stop working, like video acceleration, etc.
I just tried it and successfully updated to 20.10 from the pbpro Ubuntu mate image 20.04. I will have to play with it to see if there are any deficiensies.
First thing to notice is that the keyboard layout is out of whack. Trying to figure out which keyboard to go with. Need to review the pinebook wiki for ANSI layout. Anyone know which one to use?
I upgraded too and it went smooth and it works well, even better than on my x86 laptop (it has a problem with sound)
Kernel stayed the same, GPU acceleration and sound works, no problem.
There was some additional keyboard switcher in the tray, so I just uninstalled all "ibus*" packages and rebooted.
Sorry I'm still a bit of a newb, how do you remove the ibus* packages?
Just started Muon package manager and searched for "ibus" string in package name and removed all the installed packages that contained "ibus" in its name.
(10-06-2020, 06:23 AM)Wizzard Wrote: Just started Muon package manager and searched for "ibus" string in package name and removed all the installed packages that contained "ibus" in its name.
I'm not sure if I flashed the correct image of Ubuntu. My install came with bare minimum. I don't even have the muan package manager. Neither is there libre office or anything. I tried to run the command below to see if it would install the missing apps.
Sudo apt-get install ubuntu-desktop
It loads and says its already installed with nothing new. I flashed the pinebook image from ayufan.
I think you can just run a command like "sudo apt-get remove ibus*" and it should remove all those packages.
(10-07-2020, 12:37 AM)Wizzard Wrote: I think you can just run a command like "sudo apt-get remove ibus*" and it should remove all those packages.
Thank you for your support!
Is this the Ayufan Ubuntu or the Armbian Ubuntu? Or is there another Ubuntu...?
  After update in Ubuntu bionic mate system crashed Wawe 2 7,320 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu Installation on PBP narinderpal10 5 12,240 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,606 12-15-2020, 01:53 AM
Last Post: BryanF
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 33,356 11-19-2020, 03:16 AM
Last Post: FeMike
  Ubuntu 20.10 bastafari 6 12,716 10-27-2020, 10:16 AM
Last Post: Mangled
  How does one get working deep/S3 sleep with Ubuntu Focal/5.7 mainline kernel? Syonyk 7 16,305 10-26-2020, 02:03 PM
Last Post: edward
  ANSI keyboard fix for ubuntu Mangled 0 3,361 10-05-2020, 02:15 PM
Last Post: Mangled
  Debian (or ubuntu) on a micro sd card (pinebook pro) pine76 28 64,628 09-06-2020, 08:20 AM
Last Post: pine76
  Ubuntu for RockPro64 dndeokar 1 5,462 08-14-2020, 06:42 AM
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 45,321 07-02-2020, 11:04 AM
Last Post: mlentink
