PCI-e to Dual SATA-II Interface Card only works with one disk
Hi @Nikolay_Po , thanks a lot for your answer and description of your setup - it sounds very similar to mine.
As written above, I'm using the same power supply as you do. Also, as written above, I tried powering the HDDs with a separate (ATX) PSU and that didn't help. I even tried with yet another secondary ATX PSU, so it's definitely not the power supply - unfortunately, as this would be easy to fix.
Running out of ideas, I now ordered a Marvell-based SATA card and hope that this will fix my problem. I will report here whether it did.
RE: PCI-e to Dual SATA-II Interface Card only works with one disk - by taube - 11-29-2019, 08:31 AM
  AW-CM256SM wifi card mtek 4 2,480 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 972 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 603 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 465 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,610 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,254 12-18-2022, 06:25 PM
Last Post: heyghoge
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,403 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,124 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 45,016 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 3,037 09-15-2021, 12:46 PM
Last Post: corax
