PCI-e to Dual SATA-II Interface Card only works with one disk
Hi
after extensive testing of my newly arrived setup I pinned down the problem described earlier (https://forum.pine64.org/showthread.php?tid=8359 and https://github.com/ayufan-rock64/linux-build/issues/299) to the official PCI-e to Dual SATA-II Interface Card. As I'm pretty sure that the card is the culprit in this case, I'm re-posting the problem here.
My setup:
RockPro64 4GB
2x4TB Seagate IronWolf 3.5" HDD
NAS case with fan and Pine64 power supply (5A)
With two HDDs connected, the system does not boot or crashes frequently (power cycle required to reboot). Before the crash, I can hear the HDDs repeatedly "trying to spin up". I tried with different OS images, including ayufans openmediavault builds (version 0.9.14, armhf and arm64) and "vanilla" armbian buster server (kernel 4.4). Both HDDs are working (tested using an USB-to-SATA adapter) and both SATA cables are tested and OK. Powering the HDDs with a separate PSU didn't help, so the power supply is not the problem.
Connecting only one hard drive to either of the two SATA connectors works without problems. I also tried hot-plugging the second hard drive, which results in the following dmesg output (repetitive, for ata1 or ata2):
[  322.470646] ata2: exception Emask 0x10 SAct 0x0 SErr 0x4050000 action 0xe frozen
[  322.470669] ata2: irq_stat 0x00400040, connection status changed
[  322.470687] ata2: SError: { PHYRdyChg CommWake DevExch }
Searching for this error, most people seem to suggest a broken cable. I remember reading somewhere on this forum that the signal quality of the PCIe card is not the best, which would explain why two cards could potentially "interfere" on the hardware-level. Did anyone experience similar issues and knows how to fix them?
Otherwise it seems that the pine64 was a total misbuy and I have to find another SATA card now...
PCI-e to Dual SATA-II Interface Card only works with one disk - by taube - 11-25-2019, 07:44 PM
  AW-CM256SM wifi card mtek 4 2,372 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 918 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 569 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 447 09-15-2023, 04:20 AM
Last Post: JPT223
  Compatible PCIe Sata Controller spacebricker 1 1,580 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,955 12-18-2022, 06:25 PM
Last Post: heyghoge
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,389 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,092 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
  Rockpro64 Sata Card kills itself jerry110 33 44,518 10-20-2021, 04:36 AM
Last Post: fieni
  Right direction SATA card corax 2 2,996 09-15-2021, 12:46 PM
Last Post: corax
