My RockPro64 died after 8 months
I agree with @Nikolay_Pro ... buzzing is a sign of a potential problem... either imminent or in the future. I would have been checking the inductors to see if any were cracked, or if pressure on any of them stopped it, and then given it a dose of epoxy to deaden the vibration or replaced it as the case may be.
If you're still interested in the schematic, here it is from the wiki information page for the rockpro64. Datasheets for all the major components are there also.
The fact that it powered down, and then stopped working actually sounds promising... sounds like something just isn't starting up again properly. The two LEDs(white/red) are both on the 3v3 rail as they are directly controlled by the RK3399, so unfortunately won't work unless the main CPU boots (and 3v3 present!), so don't tell you much more than that. Anyway, page 11 is a good place to start, and from the looks of it, if you check the RPi Header 5v and GND pins, that should always be present if the rockpro64 has power - looks to be the 'hardwired' system 5v, so check that first. If it's present, carry on to page 18, as it's probably one of the PMIC outputs that's gone.
My RockPro64 died after 8 months - by diskers - 11-23-2019, 12:14 PM
RE: My RockPro64 died after 8 months - by diskers - 11-27-2019, 08:24 AM
RE: My RockPro64 died after 8 months - by diskers - 11-28-2019, 04:07 AM
My RockPro64 died after 8 months - by Antony - 11-28-2019, 01:26 PM
RE: My RockPro64 died after 8 months - by xalius - 11-28-2019, 01:35 PM
RE: My RockPro64 died after 8 months - by diskers - 11-30-2019, 12:43 AM
RE: My RockPro64 died after 8 months - by diskers - 11-30-2019, 12:09 PM
RE: My RockPro64 died after 8 months - by Antony - 11-30-2019, 08:49 AM
RE: My RockPro64 died after 8 months - by pfeerick - 11-30-2019, 06:16 PM
RE: My RockPro64 died after 8 months - by diskers - 12-08-2019, 12:42 PM
RE: My RockPro64 died after 8 months - by diskers - 01-09-2020, 03:51 PM
RE: My RockPro64 died after 8 months - by tllim - 03-09-2020, 11:29 PM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,309 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 958 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,254 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 878 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,695 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,850 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,185 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,548 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,234 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,792 05-16-2022, 02:34 AM
Last Post: dukla2000
