Rockpro64 PCI-Express Issue.
(04-23-2020, 05:54 AM)t4_4t Wrote: > rockpro64-nocapacitors2.jpg
I saw the jpg you posted, it's probably a board that's already fixed.
I think that the resistance "R89506 / R89507" was changed to 0Ω and the capacitor "C50007 / C50008" was left as it was.
This is exactly what I did.
The impedance of the PCIE transmission line is specified as 50Ω.
For this standard, the effect of the capacitor "C50007/C50008" is 1Ω or less, and even if there is, it has almost no effect.
On the other hand, the resistors has an error of +50Ω or more with respect to the standard value of 50Ω, which is an unacceptable error.
You can check whether it is working properly by the following method.
# lspci -vvv | grep Speed
               LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
=>             LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
               LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
               LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s <1us, L1 <8us
               LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
> I am getting only 560-580 MB/s in `hdparm --direct -t` test with a Samsung 970 Evo that...
Please refer to the post below.
The Performance varies depending on the kernel type and test method.
https://forum.pine64.org/showthread.php?...1#pid39681
The Rockpro64 can do 5GT/s?
Currently the rk3399 pcie controller is limited to pcie gen 1 in the dtsi.
`max-link-speed = <1>;`
Rockpro64 PCI-Express Issue. - by t4_4t - 11-18-2019, 09:22 PM
RE: Rockpro64 PCI-Express Issue. - by maya.b - 11-19-2019, 08:02 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-17-2020, 05:46 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-17-2020, 12:21 PM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-19-2019, 07:34 PM
RE: Rockpro64 PCI-Express Issue. - by dukla2000 - 11-20-2019, 04:24 AM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-20-2019, 07:51 AM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 11-20-2019, 09:44 AM
RE: Rockpro64 PCI-Express Issue. - by dukla2000 - 11-21-2019, 03:46 AM
RE: Rockpro64 PCI-Express Issue. - by fysa - 02-19-2020, 09:06 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-22-2020, 08:56 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-22-2020, 09:08 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 04:55 AM
RE: Rockpro64 PCI-Express Issue. - by dsimic - 12-17-2020, 10:01 AM
RE: Rockpro64 PCI-Express Issue. - by tllim - 12-23-2020, 05:18 PM
RE: Rockpro64 PCI-Express Issue. - by dsimic - 12-27-2020, 05:11 PM
RE: Rockpro64 PCI-Express Issue. - by t4_4t - 04-23-2020, 05:54 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 07:33 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 07:56 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 08:02 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 08:38 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 10:28 AM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 11:22 AM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 12:06 PM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 01:17 PM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-23-2020, 02:27 PM
RE: Rockpro64 PCI-Express Issue. - by kuleszdl - 04-23-2020, 04:52 PM
RE: Rockpro64 PCI-Express Issue. - by pgwipeout - 04-24-2020, 11:27 AM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,343 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 964 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 26,289 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 880 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,703 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,883 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,189 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,571 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,237 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,797 05-16-2022, 02:34 AM
Last Post: dukla2000
