Always in 'Charging' state, despite being disconnected from external power
(01-07-2020, 05:17 PM)bcnaz Wrote: Have you tried running a different OS from an SD card  ?
   Just curious,  That could be a step in determining if it is a software or hardware problem.
Meanwhile I tried Manjaro (KDE Plasma). With it the state is reflected 95% correctly.
  • Charging via barrel plug or USB-C -> battery widget indicates charging state
  • No power adapter connected -> battery widget indicates discharging state
  • Charging via USB-C power adapter, then unplugging the power adapter from the wall socket, leaving the USB-C side attached to the Pinebook -> battery widget continues indicating charging state.
RE: Always in 'Charging' state, despite being disconnected from external power - by bigCamel - 03-13-2020, 04:40 PM
Photo P{inebook Pro not charging Ome Ko 6 2,113 11-09-2023, 03:29 PM
Last Post: tomekdev
  Lockable-until-power-cycle persistent storage Melab 0 758 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 870 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 652 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,312 02-25-2023, 09:00 PM
Last Post: badguru
  Pine Book Pro Charging Problems balin 7 7,050 12-15-2022, 02:15 PM
Last Post: tomasgreenro
Heart Now better battery life or power management? KC9UDX 5 2,380 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,636 02-22-2022, 11:20 AM
  Issues with External Display After Recent Update reundo 0 1,414 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,273 11-17-2021, 10:02 AM
Last Post: Phillip Bell
