Remote-viewer "Bus Error"
Okay, this is going to be a bit of a long shot, because I'm really not an expert on how all this stuff works, and barely even understand the nuts and bolts of how libraries get organized and used under Linux. However, I also hit the mysterious "bus error" problem myself, and in my case, I found a way to fix it that worked, so I figure I might as well share.
For me, this happened with `zpaq`, which is a very small high-performance archive compressor that I use a lot. At first, I had no idea what to try, but then when attempting to build from source, I ran across this in the readme:
-DNOJIT  = turn off run time optimization of ZPAQL to 32 or 64 bit x86
          in libzpaq. Use this for a non-x86 processor, or old
          processors not supporting SSE2 (mostly before 2001).
That was, as far as I can tell, it. When I recompiled using this flag, everything was fine. I guess the maintainer of zpaq (and lrzip, a similar tool that produced a similar error when I tried it) overlooked this when they committed their build to the repos?
In any case, if building from source is an option for you, it seems like this problem may sometimes be caused by incorrect runtime optimizations being enabled, and can be corrected by disabling them.
Good luck!
Remote-viewer "Bus Error" - by wingmanjd - 11-04-2019, 02:26 PM
RE: Remote-viewer "Bus Error" - by mfritsche - 11-08-2019, 09:21 AM
RE: Remote-viewer "Bus Error" - by wingmanjd - 11-08-2019, 10:25 AM
RE: Remote-viewer "Bus Error" - by mfritsche - 11-08-2019, 03:09 PM
RE: Remote-viewer "Bus Error" - by wingmanjd - 11-11-2019, 01:28 PM
RE: Remote-viewer "Bus Error" - by diodelass - 11-11-2019, 06:47 PM
RE: Remote-viewer "Bus Error" - by wingmanjd - 06-09-2020, 07:29 AM
  Error On Initial Setup HankLubowitz 2 591 11-21-2023, 05:36 PM
Last Post: igorp
  Error trying to update Manjaro software boosterh 5 2,966 08-31-2022, 10:28 PM
Last Post: shulamy
  extlinux.conf file error, can it be edited in bootloader? Abandoned Brain 2 2,596 09-26-2021, 01:28 PM
Last Post: Abandoned Brain
  Error Log has a few scetchy things. Manjaro Xfce SpaceLord 0 1,544 05-23-2021, 10:49 AM
Last Post: SpaceLord
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 9,037 09-29-2020, 07:55 AM
Last Post: hmuller
  Error when running pinebook-pro-keyboard-updater NoahB 13 15,347 07-29-2020, 06:33 PM
Last Post: guiltydoggy
  pinebook pro manjaro xfce pacman network error thumbsup 1 3,056 07-11-2020, 02:32 PM
Last Post: thumbsup
Question Where is fusermount? (rclone mount error) davemaps 1 2,941 07-02-2020, 01:04 AM
Last Post: hvdkooij
  Error when trying to install local package with pkcon koenigs 0 1,947 05-11-2020, 03:22 AM
Last Post: koenigs
  VMware remote for arm or equivalent JaceAlvejetti 2 3,597 01-26-2020, 06:07 AM
Last Post: JaceAlvejetti
