Where is fusermount? (rclone mount error)
Question
I’m attempting to mount some cloud storage using rclone mount, but it is complaining about fusermount not being found in $PATH. Running “which fusermount” yields nothing. Fuse seems to be installed, but how do I get or find fusermount? I’m on a new Pinebook Pro running the stock Manjaro install. I installed rclone using “curl https://rclone.org/install.sh | sudo bash” Thanks!
I have been following https://www.linuxuprising.com/2018/07/ho...using.html and it seems to work well up to the actual mounting stage.
You need to add fuse as package with: sudo pacman -S fuse
Does that resolve your issue?
  Error On Initial Setup HankLubowitz 2 506 11-21-2023, 05:36 PM
Last Post: igorp
  Error trying to update Manjaro software boosterh 5 2,808 08-31-2022, 10:28 PM
Last Post: shulamy
  extlinux.conf file error, can it be edited in bootloader? Abandoned Brain 2 2,537 09-26-2021, 01:28 PM
Last Post: Abandoned Brain
  Error Log has a few scetchy things. Manjaro Xfce SpaceLord 0 1,501 05-23-2021, 10:49 AM
Last Post: SpaceLord
  Error when running pinebook-pro-keyboard-updater NoahB 13 15,045 07-29-2020, 06:33 PM
Last Post: guiltydoggy
  pinebook pro manjaro xfce pacman network error thumbsup 1 3,000 07-11-2020, 02:32 PM
Last Post: thumbsup
  Manjaro KDE 20.04 - cant even mount SD card after dd Manjaro from SD to emmc rolf 0 1,982 06-20-2020, 10:01 AM
Last Post: rolf
  Remote-viewer "Bus Error" wingmanjd 6 7,640 06-09-2020, 07:29 AM
Last Post: wingmanjd
  Error when trying to install local package with pkcon koenigs 0 1,899 05-11-2020, 03:22 AM
Last Post: koenigs
Question Mount eMMC after booting from SD card User 11436 3 5,293 03-16-2020, 02:36 PM
Last Post: lxn
