PCI Express x4 Device Support
(09-19-2019, 09:33 AM)iops/watt Wrote: While these versions of Linux recognize and effectively support the boards, I cannot get any version of the SAS2Flash, SAS2IRCU or LSIUtil to run from the command line.  MPT3SAS and MPT2SAS (drivers?) both load at bootup but I can't re-flash the boards while installed in the RockPro64 nor can I load any BIOS/firmware app to configure the boards in IR (integrated Raid) mode.  IT mode is working fine with OpenMedia vault but I would like to benchmark and experiment with the IR mode.
Any suggestions or workarounds would be appreciated.
From the looks of things SAS2Flash and SAS2IRCU both require *native* EFI firmware support.
While it is possible to get U-Boot to emulate EFI for the purpose of booting Linux, it doesn't support the low level functions those programs need to run.
It may be possible to get it to run on an enterprise ARM64 board that has native EFI support.
LSIutil appears to be x86_64 only.
You may have luck running qemu-x86_64-static LSIUtil, but I do not have a LSI card to test this and it too may require EFI support for some or all functions.
PCI Express x4 Device Support - by machinevault - 09-13-2019, 02:34 AM
RE: PCI Express x4 Device Support - by iops/watt - 09-19-2019, 09:33 AM
RE: PCI Express x4 Device Support - by revoman - 07-07-2020, 10:26 PM
RE: PCI Express x4 Device Support - by amiraeva - 07-08-2020, 08:38 AM
RE: PCI Express x4 Device Support - by pgwipeout - 07-13-2020, 01:32 PM
  PCIe bifurcation support (on RK3399) Arn 1 1,347 11-28-2022, 05:12 PM
  Support for Refresh rates Above 60 publiclewdness 0 1,279 01-01-2022, 11:40 PM
Last Post: publiclewdness
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 28,436 12-13-2021, 11:04 AM
Last Post: Cerberus
  Rockpro64 PCI-Express Issue. t4_4t 27 32,547 12-27-2020, 05:11 PM
Last Post: dsimic
  PCI-E Express card with SIM card slot for rockpro running android 8 seaurchin 3 4,735 07-21-2020, 07:58 AM
Last Post: pgwipeout
  Problems with maskrom OTG USB in Linux - Device not responding to setup address nutilius 0 1,778 08-31-2019, 11:40 AM
Last Post: nutilius
  Need to add various Wifi chipset support slappymcphee 6 8,134 08-15-2019, 05:26 PM
Last Post: evilbunny
  JMicron cipset SATA PCI-E card support Yroth 2 4,046 07-27-2019, 08:52 PM
Last Post: stuartiannaylor
  USB fails to power device? BackWoodsTech 12 13,588 12-13-2018, 07:26 AM
Last Post: BackWoodsTech
  Marvel 9215 Sata controller support MisterA 6 10,355 09-26-2018, 11:41 AM
Last Post: MisterA
