USB fails to power device?
I have a small USB router. It has a USB powerc cable wirh an AC power adapter. It works just fine when using like one of those outlets that just has a usb port, but when I attempt to power the device off the rock pro USB it boots then shutsdown..boots, shutsdown repeat.
Is the USB port insufficient to power peripherals?
(12-08-2018, 03:09 PM)BackWoodsTech Wrote: I have a small USB router. It has a USB powerc cable wirh an AC power adapter. It works just fine when using like one of those outlets that just has a usb port, but when I attempt to power the device off the rock pro USB it boots then shutsdown..boots, shutsdown repeat.
The rp64 is only designed to be powered from the 12v socket, this was intentionally designed this way so hdd's would have power from the board
Let me clarify: the rockpro is powered off an outlet. But the USB Fails to power the small router
(12-09-2018, 06:49 AM)BackWoodsTech Wrote: Let me clarify: the rockpro is powered off an outlet. But the USB Fails to power the small router
No, that's not normal and you should contact support@pine64.org
Update
I did open a support ticket but not too confident I'll see a response.
Just to cover my bases: i tested both USB 2.0 ports and still the same behavior.
Using the USB 3.0 port however and the device worked as expected.
Does this offer any insight?
(12-10-2018, 07:17 PM)BackWoodsTech Wrote: I did open a support ticket but not too confident I'll see a response.
They do respond, but responses can take time, depending what else is going on.
Quote:Just to cover my bases: i tested both USB 2.0 ports and still the same behavior.
For the sake of completeness what power supply do you use?
The 5A powersupply which was recommended for the board. I think I surced everything drof Ameridroid
(12-10-2018, 07:17 PM)BackWoodsTech Wrote: Just to cover my bases: i tested both USB 2.0 ports and still the same behavior.
How about the RockPro64 properly implements USB2.0 and limits the power to 500mA. Whereas USB3.0 allows more (I am no expert, 1 quick answer from Prof Duck indicates 900mA). And your router needs >500mA @ 5V?
that's an interesting thought. IIRC when I ran the device via a Kill A Watt meter it was only using like 2 Watts (~0.5Amps).
I'd sure hate to have to occupy the sole USB 3.0 port on this just because of a problem with the USB 2.0
One thing I am wondering is if there's a default setting for the USB 2.0 that's trying to mount the device rather than charge it? I guess that makes no sense.
FWIW this is on OMV 4.x (Debian Stretch).
UPDATE: the device does say 5v 2A.
(12-11-2018, 02:42 PM)BackWoodsTech Wrote: One thing I am wondering is if there's a default setting for the USB 2.0 that's trying to mount the device rather than charge it? I guess that makes no sense.
Could be - but you should see noise in the system log then if the "presented" USB device is changing (dmesg or journalctl).
(12-11-2018, 02:42 PM)BackWoodsTech Wrote: UPDATE: the device does say 5v 2A.
Most likely an absolute max that is theoretical and never reached. But does indicate >500mA very likely, and thinking back to your OP (boot, shutdown, repeat) does tend to say it is almost OK, gets to a point where it cant get enough power so shuts down ...
lsusb -v reports what power a USB device is limited to: I am sure a very crude measure on USB 2 ports but if you run the router on the USB 3 port then it may be a bit more useful. (My DVB stick in a USB2 port says 500mA - it is a USB2 device and so is clearly happy running somewhere under 500mA but no idea how much under. My Bluetooth dongle only asks for 100mA.)
But bottom line I figure you should use the power adapter.
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,060 04-01-2024, 10:24 PM
Last Post: nano2
  RP64 Won't Boot After Power Down ColPanic_ 10 7,839 06-27-2023, 07:31 AM
Last Post: dkebler
  NAS Setup: Hdds PSU external power option Robotik 1 1,733 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,918 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,306 01-28-2022, 09:45 AM
Last Post: actionhank
  How to add an external power button? foresto 6 9,130 02-05-2021, 10:38 PM
Last Post: foresto
  NAS mods: external serial port and power button foresto 4 6,556 10-04-2020, 11:21 PM
Last Post: zer0sig
  Power Supply - Barrel length Wiing 2 3,610 09-20-2020, 12:38 AM
Last Post: Wiing
  PCI Express x4 Device Support machinevault 4 7,435 07-13-2020, 01:32 PM
Last Post: pgwipeout
  Problems with maskrom OTG USB in Linux - Device not responding to setup address nutilius 0 1,775 08-31-2019, 11:40 AM
Last Post: nutilius
